Old 09-29-2021, 05:13 PM
AnthonyS's Avatar
AnthonyS AnthonyS is offline
Interesting read Kevin.
If you like, I have this one available:
https://www.yenko.net/forum/showthread.php?t=168895
Just shoot me an offer before I put it on eBay.
You’ve got more patience than I would on this
Cheers,
Anthony
Old 09-30-2021, 04:16 PM
KevinW KevinW is offline
I heated the 1st weld up this morning, did not see any cracks! Went ahead and welded the 2nd crack (underneath the first). I grinded the crack and started from the feathered edge. Did a bead, grind, another bead, grind, etc. Working my way from the small end to the big end. Worked on the mating edge a bit more and made sure it is flat with a straightedge.
The welds look good, no cracks that I could see. Mounted it up to a head and torqued to 20 ft/lbs. All looks good
Now I can media blast it and paint it, put on the studs and call this project done!
69 327 convertible (driver)
The Following User Says Thank You to KevinW For This Useful Post:
SuperNovaSS (10-02-2021)
