Pro Built 86 Camaro
$21000.00 or Best Offer
Immaculate professionally built '86 Camaro that can also easily double as a pump gas prostreet car. This rock solid car runs lazer straight down the 1/4 mile in the low 9's and is the safest in it's class with a 14 point roll cage and full halon fire system. No expense has been spared with over $72K invested as can been confirmed by the extensive build sheet below. All certifications are up to date and this car is ready to race. There are 32 passes on this car since build completion. I am also including ET Street front tires on aluminum wheels and ET Street rear slicks that can be remounted to completely make it street legal and a passenger seat w/belts. All headlamps, tail lamps, turn signals, etc and power windows are functional. Also included is the original factory rear spoiler that can be easily reinstalled if desired. Body is straight and the Corvette Torch Red paint is as close to show quality as it gets. The car was just dyno tuned, scaled, and setup making it deadly consistant. One of the outstanding features of this car is the nitrous controller which makes class selection very flexible without having to change jets allowing it to be run in a few 9.00 and 10.00 index classes. No detail has been overlooked in building this car. As with all vehicles of this type, it is sold as is. Call 248-330-6016 or e-mail, [email protected] 1986 Camaro Z28 421ci SBC J&E Nitrous Pistons - 4.150 bore, 10.5:1 compression w/CA rings LA Billet Kryptonite H Beam Rods 5.85 center to center Clevite H Bearings Scat 4340 Crank 3.875 Stroke Melling M77 high volume oil pump Canfield 220 angle plug 60cc aluminum heads 2.08 int/1.60exh - ported by AES Isky Cam Lift 672 int/672 exh, duration 314 int/322 exh Comp Cams Solid Roller Lifters PAC 1226 Valve Springs Comp Cams Pushrods Harlan Sharp Offset 1.6 Ratio Aluminum Rockers AFR Offset Stud Girdle Hurricane aluminum single plane intake Engine Balanced and Assembled by AES Elk Grove, IL. 600+ HP Moroso 22640 Vacuum Pump System Ed Quay 1.875 Coated Headers MSD 6520 Digital 6 Plus Ignition Control FAST 301270 Crank Trigger MSD 84697 Pro Billet Crank Trigger Distributor MSD 8253 HVC-2 coil MSD 31239 plug wire set NGK #9 (R5671A-9) racing spark plugs Magnaflow MAGMP-4550 Pro Star 500 Fuel pump w/filter Holley 12-803 max pressure nitrous fuel pressure regulator MagnaFlow MP-9433 4 port carb fuel pressure regulator Cold Fusion CFN 500 200-600 HP Fogger Nitrous Kit w/purge jetted for 300 HP Nitrous Express 15964 Digi-Set Nitrous Timer Nitrous Express SPEED00020 Fire and Ice Pressure Controller NOS 16058 Remote Bottle Opener System Holley 4150 850cfm carburetor Fram HPK600 remote oil filter adapter CSR 901R electric water pump C&R aluminum radiator Perma-cool dual circuit fluid cooler Flex-A-Lite 180 electric fan Centerline Qualifier 15x4, 1.75 front aluminum wheels Aluma Star 15x14 5x4.75 5.5BS rear aluminum wheels Mickey Thompson ET Drag 26x4.50-15 front tires Mickey Thompson 32/14x15L ET Drag rear slicks Aerospace Components AC-225 Front Brakes Aerospace Components AC-510 Ford Rear Brakes Hurst Roll Control Mark Williams 57015 Ford 9 Aluminum Thirdmember, 35spline Locker, 456 gears Mark Williams 50100 Hi-Torque Axles Jerry Bickle drive shaft w/Spicer joints/flanges rated to 2500HP Coan TH400 3spd reverse pattern w/trans brake rated to 1500hp Bradco Engineering 9 nitrous converter 4500 stall, .09 mid plate 168350S SFI 168 tooth flex plate CSR 835 flex plate shield TCI 980000 trans shield DRE NHRA Approved Engine Diaper Cheetah 70012 SCS shifter w/command center Biondo Racing CO2 Air Shifter Mark Garland/Precision Products Built Chassis Jerry Bickle tube 4 link back half Chassis scaled and setup by Skinny Kid Racecars Walled Lake, MI Skinny Kid Racing Rear Anti-Sway Bar Chassis NHRA/IHRA Certified to 8.50 both expire March 2014 Lakewood 40510 90/10 front coilover struts Art Morrison rear coilover springs/shocks Autometer Pro Comp Ultra Lite gauges 12 gal fuel cell Powermaster 47861 140 Amp Alternator Bullitpruf SS-1 Starter Jacobs FR1500 Accu-Volt regulated power supply system RJS Racing 5pt Harness Certified until March 2012 PA Racing chrome-moly K member and adjustable lower control arms Ed Quay aluminum rear spoiler Simpson parachute with removable mounts Firebottle RC1000 SFI 3 Nozzle Halon On Board Fire Extinguisher System Custom overhead roll bar mounted switch panel |
Re: Pro Built 86 Camaro
Sold!!
