#11
Re: Two 427s
The carb spacer can be worth 20hp +/-.
#12
Re: Two 427s
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Vortecpro</div><div class="ubbcode-body">
Thanks for the replies. Engine number 1. has been tested and made 575 HP @ 6500 RPM, very impressive when you consider the factory cam specs, I could see the vacuum coming in at 16 inches at idle. I ran the the engine to 6600 and was down 1 HP, I really like the way the 427 carries the power out, this is very important to me. Engine number 2. will be tested this week, I will post the results. Its interesting todays 236 headed flattop piston Super Stock 454 makes right at 720 HP, with the 049 headed version making 740. Ken, I would be interested in where your S/S 454 peaked?</div></div> If my memory serves me right, I believe it was 6700 RPMs This was with a Comp 280 284 [email protected] 748 748 110 in@ 108 Lash IN..040 EX. .025 |
#13
Re: Two 427s
I'd like to see the torque numbers on both engines.
#14
Re: Two 427s
Here you go, not the best pull but a good average one. Engine 1.
#15
Re: Two 427s
Something tells me that engine 2 will have quite a bit more area under the curve... [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Remember the days of carburetors,chrome,and leaded gasoline? 1969 Nova SS L78 4-speed |
#16
Re: Two 427s
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Vortecpro</div><div class="ubbcode-body">Engine 1.
Blue printed .060 over L72 427, 12.2 compression, 242/242 520/520 solid lifter cam, stamped LS-6 rocker arms, stock GM 840 rectangle port heads, 2.190/1.720 valves, factory 163 intake, 4 quart factory oil pan. Engine 2. .060 over 427 10.3 compression, 264/264 560/560 solid lifter cam, roller rockers, ported GM oval port 781 heads, 2.190/1.880 valves, Performer RPM air gap intake, 1 inch open spacer, Moroso oil pan. Both engines will be tested with the same Holley carb, 2 inch headers with mufflers, which one will make more power? __________________ </div></div> Mark, you and I both know better. We have talked a few times and not sure if these guys realize WHO is posting!! Motor 2 has a very unfair advantage as it was out together by <span style="font-weight: bold">one of the BEST oval port engine builders in North America</span>. I just wish you were close and not over that "imaginary" line called A BOARDER. What you should have done is post motor 1 against Wilson 496? That would have opened some eyes on these guys. John (or you would know me as NPS NOVA on our "other" site, lol)
'58 Apache pick up '78 Z28 4sp being restored '70 W30 convert TRIBUTE '78 Z28 32,000 survivor, Og Yellow paint, AC. '69 CANADIAN Nova SS 396/350 hp '67 CANADIAN Nova SS 427 10 sec. driver '66 CANADIAN Nova SS Race Car '61 CANADIAN Pontiac Bubble top 409+/4sp (SOLD) '31 ALL STEEL Chevy P.U. GONE (EX-WIFES NOW) |
#17
Re: Two 427s
I know who he is and what he's capable of. (That's why I picked engine #2)
Mark builds some impressive stuff. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] Another bad-fast build Like I told him over on the Chevelle forum--if I owned my own dyno, you'd likely never get me away from the damned thing. |
#18
Re: Two 427s
Thanks for the nice comments guys! I made a big mistake on this engine #2, I used a Icon 988 piston on this build and its a disaster, heavy, 1/16 3/16 ring pack, you need two men and a boy to turn the thing over, I really screwed up. I used that piston to get me right at 10.5 compression, I hope I don't let you down on this one, its really got me worried, I test it Friday, I will let you know then, wish me luck.
#19
Re: Two 427s
Just run a step test or tweak the vapor pressure a little! LOL.
#20
Re: Two 427s
Mark get up. It's Friday already, go hit the dyno. lol
John
