Old 01-02-2022, 11:47 AM
X66 714's Avatar
X66 714 X66 714 is offline
Gas stations changes brands all the time. It's not like they could buy new pumps each time. Quick cheap paint job (brush or roller) & some decals & done. Sunoco for sure on that pump. Keep up the good work. The difference between doing a pump & a car is you get to see the end results in about 90 days for a pump
...Joe
169indy (01-02-2022)
  #12
Old 01-02-2022, 01:44 PM
Wayne 511's were not exclusive to Sunoco,they were the majority though.
Kerr-McGee brand and other gas brands have been found pumping through a Wayne 511 Blender.
  #13
Old 01-17-2022, 01:36 AM
169indy's Avatar
169indy 169indy is offline
Zinc Plating: Before and After
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following 8 Users Say Thank You to 169indy For This Useful Post:
69M22Z (01-17-2022), Edgemontvillage (01-26-2022), L_e_e (02-01-2022), NorCam (01-22-2022), olredalert (02-01-2022), PeteLeathersac (01-17-2022), X66 714 (01-17-2022), Xplantdad (01-17-2022)
  #14
Old 01-18-2022, 09:39 PM
BJCHEV396's Avatar
I'm a Sunoco guy from way back.Pump's looking great!!
169indy (01-18-2022)
  #15
Old 02-01-2022, 04:58 AM
169indy's Avatar
Default Front & Back & Sides in primer
Colorized Primed panels.
Paint is HOK line
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following 2 Users Say Thank You to 169indy For This Useful Post:
PeteLeathersac (02-01-2022), X66 714 (02-01-2022)
  #16
Old 02-01-2022, 06:01 PM
169indy's Avatar
Default Pump Top-Lid
Gas Pump Lid (Top Panel)
I elected NOT to install a Globe at this time, It should be an easy Mod to accomplish at a later date.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following 3 Users Say Thank You to 169indy For This Useful Post:
olredalert (02-03-2022), X66 714 (02-01-2022), Xplantdad (02-01-2022)
  #17
Old 02-02-2022, 09:32 PM
169indy's Avatar
Default Custom Base Rollers
I found a vintage set of Sears Metal Ball casters in Dad's garage and figured a way to adapt them to the gas pump base existing holes. I sourced alum round stock and machined adapters to allow the stems to be capture held in place with the Pump hovering around a 1/8" above the ground. This keeps the pump stable yet allows for controlled movement on a very flat concrete garage floor for maintenance and cleaning purposes. The holes are to close to the side so the casters are not able to swivel the full 360 but nonetheless it still works nice. Fun little project that put Dad's good Old (Vintage) Craftsman (Atlas) Lathe to use.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
COPO (02-03-2022), olredalert (02-03-2022)
  #18
Old 02-04-2022, 12:07 PM
A12pilot's Avatar
A12pilot A12pilot is offline
Now that’s cool. Nice work! I want to detail up the exterior of my shop like an old service station which will include a large awning, air hose reel, and a pump. There’s a guy down the street from me that has a few of the older pumps like yours in his yard. I think they’re just homes for cars right now.
Might have to wander down there and see about purchasing one. Or I might just try and make a replica!
Looking good!
Cheers
Dave
The Following User Says Thank You to A12pilot For This Useful Post:
169indy (02-05-2022)
  #19
Old 02-08-2022, 07:21 PM
169indy's Avatar
Default Electrical Completed
Thanks Guys;
Added an internal 120vac hot and switched receptacle; power for future globe and "animation" of the dual fuel-flow rotary indicators.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 02-15-2022, 06:48 PM
169indy's Avatar
Default Side Panels
More Progress; Side panels, Assembly, DIY polish of stainless steel & attaching selector, Should be Yellow or Chrome, I chose to keep it in the Orig enameled "white"
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following 4 Users Say Thank You to 169indy For This Useful Post:
69M22Z (02-15-2022), PeteLeathersac (02-15-2022), X66 714 (02-15-2022), Xplantdad (02-15-2022)
