is it or isn't it California 69 Big Block??
Need some expertise please.
I am going to look at a 69 Camaro from the California plant. The car is being said to be a big block car, but no engine, no trans. I am not sure if it has a tach to check the redline. It supposedly has the original 12 bolt rear 3.31 open carrier. It does have a big block heater core, and is disc brake equipped, there are no fuel lines in the car, but appears the sending unit is on the fuel tank. No build sheet, no POP. I am going to pull the rear seat if possible to see if any x-code written on the bulk head. Any other thoughts where to look? Based on this information what would YOU consider it? Sorry if worms are now pouring out of the can. |
If it was a stick shift car look for the big block crossmember. Also the plate on the left rear frame signifying a duel exhaust car.
The Following User Says Thank You to RobR For This Useful Post: | ||
chris slawski (07-31-2019) |
Check motor mount part numbers they are big block specific last numbers should be 113 and 114
69 RS SS L78 conv 69 RS SS ZL1 69 L78 Chevelle conv 69 L78 Nova 69 L34 Nova 67 SS Chevelle 73 Trans Am |
The Following User Says Thank You to ssl78 For This Useful Post: | ||
am i wrong to think there would be the x code on the bulkhead for a California car, or was that only Norwood pre x code tags?
Look for a build sheet on top of the gas tank. The top radiator shroud support may still be on the upper core support. Sorry, no X codes on a Los. Car
69 SS/RS 396 M20 X22 Nor 12B,72B,712 bought 1979 FULL OWNER HISTORY 69 Dick Harrell tribute Day II 427 M20 4.10 X11 76 orig pnt, 711 67 Super Stock 302 Camaro re-creation |
The Following User Says Thank You to bbbentley For This Useful Post: | ||
Devil's advocate here, with the OE drive train missing and no paper work, why does it matter what it was? Could make a nice clone, hot rod, resto-mod, whatever. Not much point in 'restoring' it.
The Following User Says Thank You to William For This Useful Post: | ||
thanks William...taht is what i was wondering, i don't want to pay big block money for a project, that would never be able to be proven as a big block.
