Old 11-04-2023, 09:46 PM
The two letters after 9511 are the ECL code and would be specific to each model of car, and what "standard" axle ratio was getting replaced. Each ECL points to a different component parts sheet, which lists what parts "go away" (the standard axle, the standard speedo driven gear, and possibly the transmission if a different internal speedo drive gear was necessary for the 4.88), and what parts get added to replace those items (plus a speedo reducer if they used one for that combo).
Camaros, Chevelles and Novas would each have different axle part numbers, so would require a different ECL suffix code for each car. And if COPO 9511 covered both 4.56 and 4.88 (and 4.10 for cars that had no 4.10 RPO available), then there would be a different sub-code (the second letter) for each of those ratios.
Anyone have any Camaro or Chevelle window sticker examples with 9511?? on them?
Jeff Helms
65 Z16 Survivor
65 Z16 drag car
66 Chevelle L78 unrestored
67 Chevelle L78 unrestored
67 Camaro SS350 Survivor
The Following 3 Users Say Thank You to jeffschevelle For This Useful Post:
67since67 (11-09-2023), big gear head (11-05-2023), JoeC (11-05-2023)
  #22
Old 11-09-2023, 01:04 PM
JoeC JoeC is offline
here is a post I did on the black Yenko sold 69 Nova that has a BV code on the POP
The Following 5 Users Say Thank You to JoeC For This Useful Post:
69M22Z (11-10-2023), dykstra (11-10-2023), olredalert (11-09-2023), RPOLS3 (11-09-2023), Xplantdad (11-09-2023)
