Old 08-31-2019, 08:29 PM
Mulsanne Blue Mulsanne Blue is offline
Default Hose Review
Fusick 3/4"
Old 08-31-2019, 09:15 PM
Default Hose Review
In my opinion, the 5/8" from Dr.Rebuild is as dead-nuts to original as I've seen. It's smooth without the tell-tale sign of the underlying cord pattern. Although my year doesn't have the repeated printed GM, the quality is excellent. It's machined applied, not rubber-stamped ink. Untraceable when removed with rag and lacquer thinner. The Fusick is also dead-nuts smooth without the cord pattern. The only drawback with the Fusick is the rib pattern. As you can see in the pic, there are four same width ribs not the three as most accept as original.
Old 08-31-2019, 09:26 PM
Default Hose Review
Dr.Rebuild 5/8" GM print. I'm not that familiar with the font that was used, so those that are, please comment.
The Following User Says Thank You to Mulsanne Blue For This Useful Post:
BCreekDave (08-31-2019)
  #14
Old 08-31-2019, 11:23 PM
67since67's Avatar
For comparison, original hoses on a '67 396 Chevelle.
MosportGreen66 (09-01-2019)
  #15
Old 08-08-2023, 11:52 AM
SBR SBR is offline
So is the 5/8 Doc rebuild hose ribbed and has the GM script?
Corvette nut since I was a kid. 67 435s and L88s are my favorites
Old 08-08-2023, 11:54 AM
SBR SBR is offline
I know that you have a very original 67 Corvette, does it still have an original 5/8 heater hose? If so, can you please post a pic of it? I am looking for a smooth 5/8 hose with ribs that is close to original as possible. I have seen originals with the GM block marking without ribs or a ribbed hose without any markings. Thanks in advance.
Old 08-09-2023, 12:30 AM
67since67's Avatar
Maybe your typo? But the 5/8 hose has no ribs.
I can't guarantee that the Vette's heater hoses are original but they satisfy the NCRS purists. The 3/4 hose is a dead match but the 5/8 hose is very slightly different than the Chevelle hose and varies slightly from the NCRS judging guide specs in the spacing. Splitting hairs here. - Bill W
Old 08-09-2023, 12:34 AM
67since67's Avatar
I'm thinking maybe PaceCar Jeff ink stamps hoses??
SBR (08-09-2023)
  #19
Old 08-09-2023, 02:36 PM
----Yes, Bill, you are correct and I remember the font being way more correct than the one example above. Not sure what hose he uses, but he might stamp what someone sends him.....Bill S
SBR (08-09-2023)
  #20
Old 08-09-2023, 03:30 PM
SBR SBR is offline
Bill, thank you for your reply. I have seen original 5/8 hoses with no ribs that have the GM block stampings on them or have seen ribbed 5/8 hoses with no GM block markings on them. It seems like no one offers a smooth ribbed 5/8 hose that is close to original. The markings what is being offered today is also not correct and I will look into what Pacecar Jeff can do with them.
