Old 01-16-2021, 09:06 PM
Default big block engine lift brackets
I've been looking at old threads of engine lift brackets trying to figure out what I have and I've got some questions.
I have a set of brackets from a '69 427 and a set that I got in a big lot of parts that I can't identify. The 427 rear bracket has a L stamp and the front bracket has no stamp that I can find.
The other rear bracket has a M inside a C and the front bracket has 3994055 and a small V stamped on it. This one has longer legs than the one from the 427, and it has sharp corners instead of rounded corners.
Is there any information on the applications of these brackets? I've seen where the '70 front bracket had the small hole for the fuel filter, but not sure what that is all about. I'm just wondering how many different versions there are of these brackets and what they were used on.
Thanks.
Attachments - The Supercar Registry 20210116_132208_resized.jpg 20210116_132154_resized.jpg 20210116_132142_resized.jpg
Old 01-17-2021, 11:22 PM
Is there any information on these? Surely someone knows something about them.
Old 01-18-2021, 04:31 PM
The painted ones are 1969. The front bracket with the V stamp is a newer style. If you are selling them, I could use the '69 brackets.
- Warren
Old 01-18-2021, 05:23 PM
The '69 brackets go with the 427 that I'm selling. I was just comparing them to the others. I didn't have any others to compare them to.
Old 01-18-2021, 10:10 PM
hiperf69 hiperf69 is offline
Good evening Freddy,
3994055 were used on ‘71-2 BB Corvettes.
Probably Chevelle, Impala,
And I’m thinking ‘73-4 also
Joe
The Following User Says Thank You to hiperf69 For This Useful Post:
big gear head (01-19-2021)
Old 01-19-2021, 01:01 AM
Unreal Unreal is offline
I thought painted ones were used on cast iron intakes, and unpainted ones were used on aluminum intakes.
Old 01-19-2021, 01:54 AM
Low Perf both were painted orange.
Hi Perf, the front bracket was painted silver and the rear one would have some orange on it, unless aluminum head.
- Warren
The Following 3 Users Say Thank You to WorkinProgress For This Useful Post:
big gear head (01-19-2021), m22mike (01-19-2021), olredalert (01-19-2021)
