Old 01-13-2021, 09:44 PM
the427king's Avatar
Default 1970 ls5 engine
TO213CRQ. 4 speed chevelle and el camino. 290 heads, intake, all dated, steel crank and rods 2799.00. guaranteed good piece no sleeves and no damage.
No Fisher priced toys here
Old 01-13-2021, 10:48 PM
CRQ is TH400 typo ??
CRT and CRU are manual, 4 speed
Pretty sure the cranks were cast in the LS5's. Mine is/was.
Old 01-13-2021, 11:30 PM
The '70 LS5 that I had was a steel crank, 2 bolt 512 block and 290 heads.
Old 01-13-2021, 11:51 PM
build date ? Mine is 1/31 and the engine builder said it was cast. Could have been swapped when the original was ground in the late 70's ??? Gone now, with the stroker kit installed.
Old 01-13-2021, 11:55 PM
the427king's Avatar
Must be marked wrong on tag, need to check pad.
Old 01-14-2021, 01:33 AM
I don't know how to decode these.
Old 01-14-2021, 02:00 AM
Assembly code stamped on the pad will start with a T and have 4 numbers after it.
In this pic of your 427, the assembly, build, date is December 4th.
Difficult to see on my pad, but it is T0130 Jan 30 CRT
Old 01-16-2021, 06:21 PM
the427king's Avatar
Pad verified as CRQ . date is correct. T400 el camino and chevelle
