Old 02-20-2019, 12:53 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Default Muncie stamp
It has no VIN, no CT , and no A, B, or C end stamp...seems to be a '70 unit given the zero after the P...guesses as to what happened here? Or simply an April 12th 1970 Muncie that did not get stamped...it is in a '69 Vehicle so not original to that car.
I ain't nobody, dork.
Attachments - The Supercar Registry IMG_0978.jpg 52510851_2378265555793858_872181255066615808_n.jpg
Old 02-20-2019, 01:46 PM
lbnaz lbnaz is offline
What is the case casting number. Looks like a 5010 case stamping which would make it a 66-67 trans. Larry
Old 02-20-2019, 01:56 PM
ssl78 ssl78 is offline
Vin could be stamped on top of the case
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 02-20-2019, 03:15 PM
Tracker1's Avatar
Thanks Larry, I think you're right - it's an earlier case than '70 : 3851325.
Old 02-20-2019, 03:33 PM
That is a 64-65 case with the smaller pin. It shows the trans was assembled on April 12th of one of those years. From memory, I believe it is 1965 because 64 has the assembly code on the cover side of the trans.
Jason
The Following 2 Users Say Thank You to SuperNovaSS For This Useful Post:
firstgenaddict (02-21-2019), Tracker1 (02-20-2019)
Old 02-22-2019, 02:50 AM
Take a look at the raised boss on top of the case at the rear. If it's rounded, it's '64. If it's square, it's '65.
Verne
The Following User Says Thank You to Verne_Frantz For This Useful Post:
Tracker1 (02-24-2019)
Old 02-26-2019, 01:20 AM
crash crash is offline
Verne
A couple years back there was a discussion about the top boss of a Muncie main case, and everyone was of the same belief, 1964 and older rounded, 1965 and newer square...
I thought I had seen 1965 cases with the round top boss...
So I went thru 75+ 325 cast Muncie main cases, and sure enough early 1965 model year Muncie main cases have the rounded top boss...
The change over came (from my observation) 2nd week of December 1964 calender year rounded , 3rd week of December 1964 calender year square...
I'm traveling right now so I don't have the exact dates with me...
Hope this helps... Crash
Old 02-26-2019, 02:59 AM
Thanks Crash. That helps my research in tracking trans VINs.
Verne
Old 02-26-2019, 01:10 PM
napa68 napa68 is offline
Sorry to hijack the thread, but anyone ever seen a stamp like this? I cannot say I have. It's from a 71 Corvette with 15,000 miles and shows no sign of ever having been out. It almost looks knurled to me
Tim
Old 02-26-2019, 08:59 PM
Jonesy's Avatar
Jonesy Jonesy is online now
Yes thats a factory XXXX out. I have that on my 1974 Z28 trans.
Someone at the factory goofed the stamping on mine.
The Following User Says Thank You to Jonesy For This Useful Post:
napa68 (02-27-2019)
