Old 08-09-2019, 08:12 PM
Enoch Enoch is offline
2 + 3 core radiator lower fan shroud mounting clips. This original piece is correct except for 67 Big Block Camaro. This factory installed piece has its original <t> in a diamond stamp. $45. Ppff
************SOLD************
Old 08-09-2019, 08:17 PM
Camaro Nova Firebird front subframe to body mounting bolts. Rbw head marking. One has minor pitting on not structural at all. Excellent hard to find original pieces. $70. Ppff
Old 08-09-2019, 10:43 PM
Camaro Nova Chevelle accelerator lever, original with L stamp. Replated many years ago. Very nice piece. $50. Ppff
Old 08-09-2019, 10:53 PM
Complete original set of 4 NOS big block windage tray studs. Been sitting on the shelf for many years. $45. PP FF (X)
Old 08-09-2019, 11:17 PM
C2 C3 Corvette under car exhaust NOS ground straps with original perfectly restored E head marking bolts with self cutting notch in tip. Also included are assembly line correct large flat star washers. The reproduction star washers don't even look close. $110. Ppff (X)
Old 08-09-2019, 11:29 PM
Very nice original AC RC 15 radiator cap. Needs new seal on the bottom. This had a solid brass rivet that someone drilled the top out to make it look hollow. This is as nice a finish as you're going to find for an original one. Perfect to restore. $50. Ppff (X)
Old 08-09-2019, 11:42 PM
Very nice original unrestored 660 thermostat housing with numbers on the flange. Great for survivor or will clean up nicely for a restored car. $55 PP FF (X)
Old 08-10-2019, 12:08 AM
63 through 67 Corvette original flat end Delco Remy dimmer switch, original rubber grommets and cut tip Phillips head mounting screws. They don't reproduce these screws correctly they don't make the dimmer switch in the original configuration and the replacement grommets are different from originals. $60. PPFF (X)
Old 08-10-2019, 12:16 AM
396 427 454 crankcase elbow breather. This is an original piece I took off a car many years ago and replated it. $35. ppff (X)
Old 08-10-2019, 12:27 AM
One pair of NOS 69 to 74 Corvette big block rear sway bar bushings. The Originals have the white section on the bottom and the two ribs running across the top. $40. PP FF (X)
