Old 03-26-2006, 09:35 PM
alben alben is offline
Default 68 L78 Holley vacuum advance question
My assembly manual for 68 Camaro shows vacuum port just rear of the passenger side carb base bolt on the DZ Holley. There is no vacuum at this port at idle, it opens to a hole above the throttle plates, which are closed at idle. Is this correct, no vacuum is reqd at idle/ Also, my only book showning initial timing advance(68 Chevrolet chassis service manual) shows 4 degrees before TDC is this enough advance? Help will be appreciated. Thanks
Old 03-27-2006, 12:55 AM
Default Re: 68 L78 Holley vacuum advance question
The distributor was set up with emissions in mind. Take it to a shop with a distributor maching and have it set up with a performance curve. Lots of easy hidden horsepower to be had.
Old 03-27-2006, 01:05 AM
Thanks much, I couldn't understand why so little advance, any distributor shop you can reccomend, also to redetail distributor at the same time?
Old 03-27-2006, 02:56 AM
TDW TDW is offline
I had a distributor done by MacNeish. Very nice work. www.z28camaro.com
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 03-27-2006, 03:03 AM
Thanks, can you give me MacNeish contact info?
Old 03-27-2006, 03:27 AM
TDW TDW is offline
If you click on the link I posted, it takes you to his web site. Tell him Tony in Michigan said hello.
Tony
55 Nomad Gasser
70 SS 427 Nova
Michigan/ Florida
