Assembly line Weatherhead petcock radiator drain
Very nice original assembly line installed Weatherhead petcock with original Weatherhead logos on the underside and 94 stamp. Originals are very hard to find. $60 ppff
Rich from my experience with 1970 Chevelle Big blocks (can't speak for other models)
The assembly line Petcocks I have seen have also had the Weatherhead or Eaton Logo right on one side of the bolt and the bottom had a unique flat head notch. See photos. What you have IMO is an over the counter unit if it does not have a logo on one bolt side.
"NOSTALGIA It takes us to a place were we ache to go again" |
The Following User Says Thank You to XXXGoldL34M20 For This Useful Post: | ||
Enoch (07-23-2019) |
Danny, thanks as always good info :-)
Here's some of the observations of some of the other original petcocks I have and the different configurations they came in. 1 brass tube no logo on underside of arms. Weatherhead stamped on flat, 2 steel tube no logo on underside of arms. Weatherhead logo on flat 3 no tube 94 + <w> stamped on arms (which is installed flats away from radiator 4 steel tube 94 <w> stamped on arms. Weatherhead stamped on flat I have also seen 1, 2 and 4 on late 60's early 70's. |
Here's a picture of some original of what I believe are assembly line eaton petcocks. They don't have stamping on the brass but they have the ridge on the underside of the arms. Most hexes have a line a vertical line or two running up and down from the stamping process.
Two more original Weatherhead petcocks. One with brass tube one with steel tube. $60 each ppff
Assembly Line Eaton Petcocks both from a 1970 Chevelle SS Big block,
Like I mentioned below that I can only reflect on 1970 Chevelle's don't know or study any other models.
New prices $45 each
$35 each
