Old 05-29-2020, 11:07 AM
COPO COPO is online now
Originally Posted by Crush View Post
Do you have Greg Smiths contact info.?
https://www.gregsmithequipment.com/
Old 05-29-2020, 12:23 PM
Zedder's Avatar
Zedder Zedder is online now
If you are 6 ft tall consider the EXT version. It has the same foot print as the std lift, but can get 79 inches clear underneath. I had the std height lift and constantly had to watch that I didn’t hit my head!
Mark
1996 Carrera & 1993 Fat Boy
The Following User Says Thank You to Zedder For This Useful Post:
Crush (05-29-2020)
  #33
Old 05-29-2020, 02:04 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is online now
We have been using the Titan lift my son won at MCACN for several years now with no issues.
https://titanlifts.com/
Mostly for storage but just used it to remove/reinstall the engine/trans in the 409
Jake Dykstra
Dykstra Motorsports
The Following 4 Users Say Thank You to RPOLS3 For This Useful Post:
dykstra (06-01-2020), markinnaples (05-29-2020), olredalert (05-29-2020), rlw68 (11-14-2020)
  #34
Old 06-01-2020, 02:54 AM
MosportGreen66's Avatar
MosportGreen66 MosportGreen66 is online now
We have a Quality 4 post. It’s great because of its compact size. Fits in smaller garages but gives you the same versatility and function of a larger unit. Was $3600 installed I believe.
Old 06-27-2020, 06:21 PM
GenZ GenZ is offline
I found a great deal on a 9000 lb. Bendpak that included the hydraulic jack, casters, and 220 volt motor for $1,600. Guy wanted to redo his garage and had $$ to burn, I guess. Was a bit of a hassle to move, but it was such a good deal I bought it, even though I had just sold my 69 Z and really didn't need it.
RPOLS3, you said that you used your lift to remove the engine? I have been trying to figure out how to do that with an engine hoist and the car still on the ramps. How did you remove the engine on the lift?
Old 06-30-2020, 01:01 PM
RPOLS3's Avatar
We just used the lift for the undercar work/trans install, we moved the car off the lift into an adjacent spot in the garage for the actual removal and re-installation of the engine. Sorry for the confusion.
Jake Dykstra
Dykstra Motorsports
Old 11-13-2020, 12:35 AM
Way late to the party here, but Nova67, did you buy a lift ?
I have 2 cheap ones, can't remember the brand, Auto something, that are only used for storage. The one on the right is taller and longer, but still wasn't tall enough for my Silverado. I have 6" of 2x8 under the legs.
I second the one complaint about needing to hold the release lever ALL the way down. The tall lift, I need to stand on a crate to reach it at the top.
I, originally, assembled them at my previous place years ago with my small forklift for the ramps. I then moved them intact to our new home and shed this spring.
Old 11-13-2020, 01:01 AM
Zedder's Avatar
Here’s my Atlas 8000lb 84 inch tall lift...
Mark
Old 11-14-2020, 11:44 AM
Zedder, looks great! What flooring is that?
Question... My installer said not to anchor it because then the self leveling mechanism won’t work?
Old 11-14-2020, 02:46 PM
Zedder's Avatar
Thanks Mosport! That is Race Deck Free Flow. It’s good if you park daily drivers in the garage in an area with snow because it lets the water and grit flow through to the cement. Then you just snap it apart in the spring and power wash it out.
Mark
MosportGreen66 (11-15-2020)
