Old 07-07-2020, 05:03 PM
Enoch Enoch is offline
67 thru 71 original Holly 4 barrel choke coil and restored cover. $40. PPFF ************SOLD************
Old 07-07-2020, 05:31 PM
Original 67 thru 69 tripower Corvette air cleaner carb stud, with dimple on top.$45. PPFF ************SOLD************
Old 07-07-2020, 05:39 PM
Big block oil line to head retaining clip and mounting bolt. BN stamped clip and RBW head marking bolt. Excellent unrestored pieces. $45. Very hard to find. ************SOLD************
Old 07-08-2020, 04:39 PM
Original 1970 through 73 TCS solenoid mounting stud. 3/8 on the bottom and 5/16 on the top end.$25. PPFF
Old 07-08-2020, 04:44 PM
Excellent original unrestored 1 1/16 inch Wittek tower clamp dated 3/69. This is for the 5/8 heater hose. You won't find a nicer one.$25. PPFF ************SOLD************
Old 07-08-2020, 04:54 PM
Original 660 thermostat housing mounting bolts; restored. Long bolt has dogbone head marking, short bolt has Rockford.$25. PPFF
Old 07-08-2020, 04:58 PM
Original survivor condition large hex 7/8 inch across the flats oil pan drain plug. TR head marking.$35. PPFF
Old 07-09-2020, 05:24 PM
Original shark fin alternator fan. Excellent unrestored condition with perfect patina. $65. PPFF
Old 07-09-2020, 05:28 PM
Excellent original 5/8 heater hose to intake manifold fitting with notches on the hex.$50. PPFF
Old 07-09-2020, 05:31 PM
Excellent survivor grade 8 AS head marking fan clutch to water pump hub mounting bolts and lock washers. Perfect patina. You won't find a nicer set of assembly line installed hardware.$45. PPFF
