Old 06-24-2019, 02:11 PM
MRIROCZ's Avatar
MRIROCZ MRIROCZ is offline
Default 1969 03E Dated COPO Parts Needed
I am in the beginning stages of restoration on my 1969 COPO Camaro. I am in need of the following items with a Date code correct for my 03E date code. Any help would be appreciated locating the following parts:
1. Carburetor
2. Air Cleaner
3. Water Pump
4. Fan Blade & Clutch
5. Radiator Shroud
6. Distributor
7. Driver & Passenger Exhaust Manifolds
8. Upper & Lower Pulley's
9. Hurst Shifter & Big Block Bracket
10. Starter
11. 837 Alternator
12. Dip Stick & Sleeve in goes into
Old 06-24-2019, 02:17 PM
Is it a cowl induction air cleaner?
Old 06-24-2019, 04:30 PM
the427king's Avatar
Have all the above
No Fisher priced toys here
Old 06-24-2019, 05:43 PM
you'd save a bundle if you replaced the word "COPO" with "L78"! Just sayin'! ;>))
Old 06-24-2019, 06:59 PM
SS427's Avatar
SS427 SS427 is offline
Yeah, I will second that!!!!!
Rick Nelson
The Following User Says Thank You to SS427 For This Useful Post:
mockingbird812 (06-24-2019)
Old 06-25-2019, 06:04 PM
What is the assembly date on your MN engine if you still retain it? You are looking for dated parts, so you need to provide for what time frame. 03E is build date of car, not engine.
- Warren
Old 06-25-2019, 06:30 PM
the427king's Avatar
Carb, dist, manifolds etc added after assembly , so possible to have dates after engine pad stamping ,but before 03E. Ill bet it would cost more for a shop to install the 3138 shifter at 100 an hour than the cost of the shifter itself ,so other than the 837 and fan clutch,the parts arent relatively that expensive.
Old 06-25-2019, 10:01 PM
L78 Fred L78 Fred is offline
If you can’t get all from Chuck or need other dates
I have a number of pieces in your date range
Fred
[email protected]
610-585-4155
WANTED:
1969 396/375 hp JH Vin N6352xx Mid April 69 block 272 casting
Always looking for dated L78 parts from Jan-Apr 69
