I am in the beginning stages of restoration on my 1969 COPO Camaro. I am in need of the following items with a Date code correct for my 03E date code. Any help would be appreciated locating the following parts:
1. Carburetor 2. Air Cleaner 3. Water Pump 4. Fan Blade & Clutch 5. Radiator Shroud 6. Distributor 7. Driver & Passenger Exhaust Manifolds 8. Upper & Lower Pulley's 9. Hurst Shifter & Big Block Bracket 10. Starter 11. 837 Alternator 12. Dip Stick & Sleeve in goes into Last edited by MRIROCZ; 06-26-2019 at 07:38 PM. |
Is it a cowl induction air cleaner?
Have all the above
Ebay Auctions http://www.ebay.com/sch/427-king/m.h...=16&_rdc=1 http://427king.com No Fisher priced toys here |
you'd save a bundle if you replaced the word "COPO" with "L78"! Just sayin'! ;>))
Sam... ![]() |
Yeah, I will second that!!!!!
Rick Nelson Musclecar Restoration and Design, Inc www.musclecarrestorationanddesign.com https://www.youtube.com/watch?v=62r-6vgk2_8 specializing in REAL LS6 Chevelle restorations |
The Following User Says Thank You to SS427 For This Useful Post: | ||
mockingbird812 (06-24-2019) |
What is the assembly date on your MN engine if you still retain it? You are looking for dated parts, so you need to provide for what time frame. 03E is build date of car, not engine.
- Warren |
Carb, dist, manifolds etc added after assembly , so possible to have dates after engine pad stamping ,but before 03E. Ill bet it would cost more for a shop to install the 3138 shifter at 100 an hour than the cost of the shifter itself ,so other than the 837 and fan clutch,the parts arent relatively that expensive.
If you can’t get all from Chuck or need other dates
I have a number of pieces in your date range
Fred L78Fred@hotmail.com 610-585-4155 3 PM-9 PM M-F 830-4 Sat 12-4 Sun EST WANTED: 1969 396/375 hp JH Vin N6352xx Mid April 69 block 272 casting for my 04C L78 Camaro that I have owned since '78 Always looking for dated L78 parts from Jan-Apr 69 I have 1969 model year JH/JD/CE/DZ blocks to sell or trade |
Thread Tools | |
Display Modes | |
