Old 09-17-2020, 05:47 PM
X66 714's Avatar
X66 714 X66 714 is online now
Default Window regulator
Anybody have an extra window regulator for the passenger door on a 1968/1969 Camaro with deluxe interior? Thank you, Joe
Old 09-17-2020, 08:57 PM
jl8z28 jl8z28 is offline
Is there a difference between the 2
Old 09-17-2020, 09:36 PM
Guy,
The post is longer for the window crank on the deluxe interior cars. That's the only difference. Dave
67 Z/28 Butternut Yellow
69 Z/28 Rally Green
69 Z11 Pace Car
2010 2SS RS Aqua Blue
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
Old 09-17-2020, 11:24 PM
X66 714's Avatar
They will have 4 rings cut into the shaft that holds the window crank handle....Joe
Old 09-17-2020, 11:56 PM
I might have an extra, I definitely have a left (Driver) side because I just removed it this week from a parts car.
69 Z/28 Rally Green
69 Z11 Pace Car
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
The Following User Says Thank You to luv2sixty9 For This Useful Post:
X66 714 (09-18-2020)
Old 09-18-2020, 04:57 AM
chads454Ls6 chads454Ls6 is offline
I might have one Joe.
The Following User Says Thank You to chads454Ls6 For This Useful Post:
Old 09-18-2020, 11:27 AM
X66 714's Avatar
If I end up with 2. that would also be fine. Both my cars use the same regulators. The one I went to install was ate up on the gear & bushing side. The bushing I could changed except it wore out the pin first. Thank you, Joe 520-490-6093
Old 09-18-2020, 05:14 PM
X66 714's Avatar
I found what I needed. Thank you everybody...Joe
Old 09-18-2020, 09:25 PM
Ok, thanxs for the heads-up
69 Z/28 Rally Green
69 Z11 Pace Car
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
