Old 12-14-2020, 12:07 AM
X77Z28MP X77Z28MP is offline
Default 69 camaro power steering gear box quick ratio
Hi looking for a power steering box quick ratio 2 1/2 turn . Im looking for a may to july 69 date Thanks in advance
69Z X77 03D Lamans Blue
Old 12-14-2020, 02:57 PM
William William is offline
All 1969 Camaro power steering gears are functionally identical. Z/28 & SS used a different pitman arm to achieve the faster ratio.
The standard Camaro SS and Z/28 power steering ratio was 16.0:1-12.4:1 [gear] 14.5:1-10.8:1 [overall]. 2.06 turns L-L. Standard production power steering gear, 5.75” pitman arm, short steering arms. Engineering info indicates N44 VRPS had one more degree of wheel angle; from 14º to 15º.
The service replacement variable ratio power steering gear was pn 3960246. It does not functionally interchange with anything; only application is the 1969 Camaro. Chevrolet admonished against interchanging standard and VR steering components:
“The pump used on vehicles with variable ratio power steering provides increased fluid flow at higher pressure than the conventional pump. Consequently, the conventional pump and the pump used with the variable ratio system are not interchangeable. A new pump outlet hose is required on variable ratio power steering equipped cars.”
-1969 New Product Training Program Booklet
“Internally, the only physical difference between the variable ratio system and a conventional system is the rack and sector gears. However, higher power steering pump pressures are required so it was necessary to strengthen the steering linkage accordingly. The relay rod is now a larger diameter, and constructed of higher strength steel. The same is true for the pitman arm. Because of the substantially higher loads imposed on the steering linkage, variable ratio steering gears should not be installed on any past model cars.”
-1969 Product Review
The Following User Says Thank You to William For This Useful Post:
X77Z28MP (12-14-2020)
Old 12-14-2020, 05:17 PM
Thanks William
I have a 69z with manual steering I want to convert it to power steering so its easier to drive. I guess i have to look deeper into this swap Thanks again for your help
Old 12-14-2020, 07:25 PM
Had a few myself back in the day. Prefer PS.
Just find any '69 Camaro sb with PS; take everything. Get a new 5.75" pitman arm and you're good to go. The car should have the shorter arms.
To be absolutely correct you will also need the 3941105 deep-groove pulley. Repros are $50-$60. For NOS, add a zero.
Old 12-14-2020, 10:11 PM
jl8z28 jl8z28 is offline
Default Power steering
I have this
The Following User Says Thank You to jl8z28 For This Useful Post:
Old 12-14-2020, 11:22 PM
nice piece but wrong date thanks for posting Still looking not much out there
Old 12-15-2020, 02:18 AM
Can you tell what the year is it could be a 8 or a 0
Old 12-15-2020, 12:51 PM
Looks like a 0 anyone else see a 0
Old 12-15-2020, 02:34 PM
Be careful with loose steering components. Only Camaro & full size had the VR steering for '69. As noted, the components can't be mixed.
Old 12-15-2020, 08:34 PM
CAN YOU POINT ME IN THE RIGHT DIRECTION AS TO PART NUMBERS OR CLASSIFIEDS ON THIS SITE. iM NOT SURE WHAT IM LOOKING FOR I WANT TO GET IT RIGHT STILL CONFUSED
YHANKS FOR YOUR HELP
The Following User Says Thank You to X77Z28MP For This Useful Post:
jl8z28 (02-19-2021)
