Old 06-05-2019, 01:58 PM
Billohio Billohio is offline
That spring is wild. Good for you taking on this project
Bill
Old 06-05-2019, 02:43 PM
----I saw many of the things you have pictured in my 2011 shop fire. Fire marshall stated that the temperature would have been around 1600 degrees to have that much damage. Really hoping your metal isn't brittle...…Bill S
Old 06-05-2019, 03:12 PM
Ryan1969Chevelle's Avatar
I am hooked already!!
I am a big fan of the amazing support people share in this hobby!!
This is way over the top!!
Ryan W31
Old 06-05-2019, 08:23 PM
mssl72's Avatar
mssl72 mssl72 is offline
Wow!! Man Dave, that's a big undertaking! As Steve said "Kudos to you Dave for undertaking this project. "!! I've always heard that there can be paint issues with metal that's been in a fire. Is it a matter of proper metal prepping, how hot the fire was or a combination of those that determines how paint holds? I'm not a body man and can't say I've ever knowingly seen a burnt vehicle before and after. I've always wondered how true the statement is. I'll be watching you on this one.
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
Old 06-09-2019, 05:18 AM
A12pilot's Avatar
A12pilot A12pilot is offline
Thanks guys! So with fresh concrete needing some dirt, I started digging in on the truck. Luckily, no rusted bolts! See? Everything has a positive side. To answer your questions, Mark, I'm not sure. I'll have to research that myself!
I'm still in shock on a few things the fire did. The start solenoid melted and fell apart yet the coil remained inside. The power brake booster came apart as one piece leaving the pushrod connected to the pedal.
So step one was to pull the engine....
Cheers
Dave
Old 06-09-2019, 05:26 AM
A12pilot's Avatar
Moving forward, with the engine out I wanted to tear it down to the long block to see what the heat might have done. Any ideas on if the head gaskets would need to be replaced?
I'm no expert, but that rotor looks like it's needing replacement! The interior shot is what's left of the A/C evaporator. Those reverse arc of the springs put so much pressure in those pins I needed to chop the spring before I could get the sledge out and pound the pins out. Of course, with every hammer of the sledge, dust and debris went flying everywhere with somehow it all ending up on me! But no matter..... we're almost roundin' the way from Truck Corner to Frame City!
Cheers
Dave
The Following User Says Thank You to A12pilot For This Useful Post:
HawkX66 (06-14-2019)
  #17
Old 06-09-2019, 05:37 AM
A12pilot's Avatar
So, after hurricane Dave moved through, I'm down to the frame! And my once clean and new shop has gone the way of the DoDo bird. But that's ok! That's the sign of progress and once I get everything sitcheated here, I'll powerwash the shop and get it all cleaned up. I mean, it's not like I'll have another hunk of a truck in here that could be any worse than this one... right? RIGHT??
Cheers
Dave
  #18
Old 06-09-2019, 05:38 AM
A12pilot's Avatar
Wrong!! Why do I get myself into these predicaments? Why can't I ever have nice cars? Why do I crave creating crap into crystal??
After looking over the truck cab, the fire did such a number on it that a donor cab was needed. So where's one to find a 1952 F1 cab laying around? Welp, glad you asked! I live in nowhereville now, and as such, these trucks are pretty plentiful around here. So, like I do eeeeevvvryyyy morning: (ssssiiippp)ahhhhh.... man that's good coffee. Alrighty, let's see...craigslist....Dallas....(tippity-type)....1952.........(enter)....hmmmm......"1952 Ford F1 flathead solid" [snort]ppllffllppp....cough....(coffee through the nose) Holy Crap! That's it!!
And two days later, it's in the shop! 100% complete 1952 F1 with an 8BA flatty and 4 gear on the floor! More to come.....
Cheers
Dave
  #19
Old 06-09-2019, 11:23 AM
Super Man Dave is back in Metropolis, Texas
Well done!
Old 06-09-2019, 01:39 PM
That is amazing craigslist had what you wanted! Looks like a pretty solid truck
Bill
