Old 07-28-2023, 02:53 AM
jbtech's Avatar
jbtech jbtech is offline
Gauges are in.
In 67 the low fuel lamp socket needs to be installed below the circuit board as the fuel module sends a positive signal. I believe a previous owner didn't realize this and fried the board. This also explains the fried wire coming from the original console harness.
Jose Betancourt
67 Camaro L78
The Following 4 Users Say Thank You to jbtech For This Useful Post:
1967Z28 (07-29-2023), 69M22Z (07-28-2023), dykstra (07-28-2023), Too Many Projects (07-28-2023)
  #192
Old 07-28-2023, 04:54 AM
jbtech's Avatar
Trim plate, radio cover plate, ash tray assembly installed. All used original GM parts cleaned with soap and water before install.
Jose Betancourt
67 Camaro L78
The Following 12 Users Say Thank You to jbtech For This Useful Post:
1967Z28 (07-29-2023), 69M22Z (07-28-2023), big gear head (07-28-2023), BJCHEV396 (08-04-2023), Dave Rifkin (07-30-2023), dykstra (07-28-2023), gtomike1967 (07-28-2023), Hawkeye (07-28-2023), napa68 (07-30-2023), olredalert (07-28-2023), SuperNovaSS (07-28-2023), Too Many Projects (07-28-2023)
  #193
Old 07-28-2023, 08:12 PM
It all looks great, Jose.
jbtech (07-30-2023)
  #194
Old 07-29-2023, 12:02 AM
SPEEDYB SPEEDYB is offline
I think this is a great car, congratulations
The Following User Says Thank You to SPEEDYB For This Useful Post:
jbtech (07-30-2023)
  #195
Old 07-30-2023, 02:04 AM
jbtech's Avatar
I cleaned, replaced grease fittings where needed, greased and installed tie rods, and idler arm. The original spare tie rods I used were in great shape.
Jose Betancourt
67 Camaro L78
big gear head (07-30-2023), Dave Rifkin (07-30-2023), dykstra (07-31-2023), R68GTO (07-30-2023)
  #196
Old 07-31-2023, 11:16 AM
dykstra's Avatar
dykstra dykstra is offline
Coming along nicely!!
Dave Dykstra
2013 Corvette Grand Sport 60th Anniversary
NCRS#66003
“Education is what you get when you read the fine print. Experience is what you get if you don’t.”-Pete Seeger
Dykstra Motorsports
jbtech (07-31-2023)
  #197
Old 07-31-2023, 09:43 PM
jbtech's Avatar
Flywheel installed and torqued per arp specs. Next I'll dial indicate bellhousing. I'm waiting for some small parts to refresh the M22.
Jose Betancourt
67 Camaro L78
big gear head (07-31-2023), dykstra (08-01-2023), L_e_e (07-31-2023), R68GTO (07-31-2023)
  #198
Old 07-31-2023, 11:13 PM
Looks great and WHERE did you get that flywheel lock ? I've never seen one like that. That must work better for torqueing than the turning tool.
dykstra (08-01-2023), jbtech (08-01-2023), napa68 (07-31-2023)
  #199
Old 08-01-2023, 07:45 AM
jbtech's Avatar
Here's the tool. Allstar Performance ALL96426. I used it on the "wrong" side but it still did the job easy peasy.
Also, I was able to use a dial indicator and the bellhousing runout is .004" so no need to use offset dowels.
Jose Betancourt
67 Camaro L78
The Following 6 Users Say Thank You to jbtech For This Useful Post:
169indy (08-01-2023), 69M22Z (08-01-2023), big gear head (08-01-2023), dykstra (08-01-2023), jer (08-01-2023), olredalert (08-01-2023)
  #200
Old 08-01-2023, 04:58 PM
Thanks, Jose, I'll be getting one soon.
jbtech (08-02-2023)
Tags
1967, 396 ss, l78 camaro
