Old 02-16-2020, 03:40 PM
wisemanz28 wisemanz28 is offline
Default 1968 Camaro Z28
Going to look at a 1968 Z28 , the car has been sitting since 1978. Original engine is gone but possibly the transmission and 12 bolt rear end are there, the body has rust around rear wheels and front driver's fender is damaged. I don't know much about 68 Z 28,s and not sure what it's worth, any feedback would be helpful.
Old 02-16-2020, 04:09 PM
scuncio scuncio is offline
Take pictures, check the axle code and inside the glove box door for the 15" tire sticker.
markinnaples (02-16-2020)
Old 02-16-2020, 04:24 PM
169indy's Avatar
169indy 169indy is offline
Look for un molested parts; 4 leaf springs, Orig Muncie Speedo Hole in firewall, 4 piston Power brake set up with all the assoc special parts, Trans Tunnel Hole reinforcement ring, a myriad of Z specific parts, Coded unique to 68Z, Alt, Dizzy, Pulleys, Rad, Shifter, wire holders, power brake hose support, basically get Jerrys Book and be very cautious since the 68's are a tough unit to document.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 02-16-2020, 05:10 PM
William William is offline
Bear in mind that no matter how much you spend on the restoration, it will never be an original engine car.
Regardless of condition, always worth less and harder to sell.
Old 02-16-2020, 05:23 PM
Search the VIN on here,FB and other internet pages,the engine might still be out there today.
Old 02-16-2020, 08:34 PM
Tried to post pics but I'm having problems doing so
Old 02-16-2020, 09:05 PM
HuggerSS HuggerSS is offline
I sent you a PM
Old 02-18-2020, 01:46 PM
Dayton Dayton is offline
Personally, with the MO engine gone, I would treat the purchase as a stock 68. I would not bite on the hype from the seller.
1969 Camaro
Old 02-18-2020, 05:16 PM
Unless it had paper illustrating something like cowl plenum and headers with 4.88 without the engine it's going to be difficult to recoup any outlay.
