Old 03-01-2020, 09:31 PM
Enoch Enoch is offline
NOS front upper shock mounting nuts. These are taller than your standard nut and gold plated. Purchased these with a set of NOS shocks 30 some years ago.$40. (X) PPFF **********SOLD**********
Old 03-10-2020, 08:18 PM
Cheville GTO 442 Original restored rear upper and lower control arm mounting hardware set. The 6 P headmarking grade 8 bolts are the shorter length bolts and the 2 P headmarking grade 5 bolts are the front lower bolts and are longer. The reproductions (for the 2 grade 5 bolts) are not correct they are too short. Excellent original restored condition. $200. PPFF
Old 03-10-2020, 08:41 PM
Camaro Firebird Nova front parking brake cable assembly. Original unrestored. Very nice. $50. PPFF ************SOLD**************
Old 03-13-2020, 06:39 PM
3 excellent original restored pair of rear tail pipe to hanger mounting bolts. E headmarking. These are usually rusted badly. Correct for 67 to 69 Camaro Firebird. $30 a pair. PPFF *****SOLD*****
Old 03-13-2020, 10:54 PM
3 excellent original Camaro firebird Nova subframes to body mounting bolts. CH head marking. Very hard to find.$80. PPFF
Old 03-15-2020, 10:40 PM
The nicest Unrestored tie rod clamp bolts you'll ever find. I picked up about 20 sets of different head markings. They are priesteen. No rounded heads no worn plating. Still have 99% of their original black phosphate coating on them. This set has NAT head marking. $40. 3 sets available. (X) ************SOLD************
Old 03-17-2020, 08:28 PM
Excellent original unrestored set of dogbone stamped lug nuts. Great original patina.$80. PPFF (X2) ************SOLD************
Old 03-19-2020, 08:40 PM
69 through 75 Corvette Big BlockF 41 big block rear sway bar cups and bushings. These are NOS pieces I've had for over 30 years. As nice original as you're going to find.$65. PPFF (X2)
Old 03-19-2020, 08:44 PM
Original 3/8 break and fuel line clips. These are the correct assembly line installed double strap style. The cut out goes all the way down to the flat. They do not reproduce these. $15 each. PPFF
Old 03-24-2020, 08:10 PM
Camaro Chevelle Nova Impala GTO upper spindle mounting bolts. WB head marking. Grade 8. Not being reproduced. $50. PPFF *****SOLD*****
