Old 06-03-2019, 05:28 PM
Steve Shauger's Avatar
Administrator
Originally Posted by MosportGreen66 View Post
What Helmut said.
Obviously someone scraped and damaged the pad. I believe the 409 did not have the traditional small/ big blocks, fore-aft broach marks, although there were circular machine markings. Hopefully a 409 guru can shed some light...
www.yenko.net
www.vintagecertification.com
Old 06-03-2019, 07:58 PM
tom406 tom406 is offline
That is pretty sad, scratching lines with an awl or something. I went through this with Verne a couple years ago. Apparently the relatively small volumes of 348/409 engines didn't justify the expense of the big planing machine that did that operation for the small blocks (and later big blocks). Thus production used a rotary machining operation for preparing the 74 degree deck surface of the W motors.
Old 06-03-2019, 11:48 PM
Looks like that would be easy to copy.
Old 06-04-2019, 02:50 AM
I’m not sure-they look kinda like regular broach marks where none of the lines intersect. You’d have to use a very large diameter, uniform grinding surface that came down on the surface flat and didn’t move laterally.
Old 06-04-2019, 11:52 AM
A friend of mine has a machine that is used for resurfacing heads and blocks that makes the same pattern when it cuts. It has a large wheel with carbide inserts. It made that same pattern on my heads when we cut them.
Old 09-18-2019, 01:31 AM
scuncio scuncio is online now
This one is back on the block for $53k - in the link below.
Link to 1963 Impala auction
Old 09-18-2019, 01:51 AM
West Chester. My Alma Mater and still only 25 mins away
