Old 10-13-2023, 07:35 PM
Oliver Oliver is offline
Default 1962 409/409 HP Engine w/Z11 air cleaner
I was going to use this rebuilt 1962 409/409 HP engine in my 1962 Belair Bubbletop project but, I’ve decided to do the car with a modern drivetrain/suspension. This is a very correct for 1962 Engine minus the carburetors. Decodes as a manual transmission dual quad 1962 409/409HP.
-ARP head studs
-New pistons
-correct 1962 exhaust manifolds with high temp coating and new hardware from show-cars
-correct 1962 winters dual quad intake manifold
-correct 1962 dual point distributor with new wires and plugs
-correct thermostat housing (not pictured)
-correct block and head castings
-new manual ball stud from show-cars
-new oil filter in correct canister oil filter
-new hardware and o-ring on breather tube from show-cars
-carburetors are not correct for 1962 (I was still undecided what carburetors I was going to run)
-new fuel lines and fuel filter from show-cars
-reproduction Z11 style air cleaner and I also have the firewall connection piece (Show-cars list for $4,999)
All casting numbers pictured below.
$23,750 Shipped (air cleaner, distributor, carburetors and possibly exhaust manifolds will be packed and shipped separately to ensure they do not get damaged)
The Following User Says Thank You to Oliver For This Useful Post:
L78_Nova (10-13-2023)
Attachments - The Supercar Registry IMG_6202.jpg IMG_6200.jpg IMG_6195.jpg IMG_6192.jpg
Old 10-13-2023, 08:03 PM
BJCHEV396's Avatar
My all time fav Chevrolet mill,what a beauty!GLWS.
Old 10-13-2023, 08:15 PM
dykstra's Avatar
dykstra dykstra is online now
Spectacular!!! GLWTS
Dave Dykstra
2013 Corvette Grand Sport 60th Anniversary
NCRS#66003
“Education is what you get when you read the fine print. Experience is what you get if you don’t.”-Pete Seeger
Dykstra Motorsports
Old 10-13-2023, 09:03 PM
mprice mprice is offline
That is just about as early of 62 block that a guy will find. If you have a very early car it can work.
The Following User Says Thank You to mprice For This Useful Post:
DW31S (10-14-2023)
