Old 04-02-2020, 06:30 PM
Steve Shauger's Avatar
Administrator
FYI I removed the spammer post and banned!
www.yenko.net
www.vintagecertification.com
Xplantdad (04-02-2020)
  #222
Old 12-26-2020, 09:12 PM
JRC99's Avatar
JRC99 JRC99 is offline
Christmas was kind.
Got a set of Accel plug wires (so I can learn how to make them in the Spring) and a pair of speakers to replace the no longer functioning ones (it has kick panel speakers that were cut into it 30 years ago- so I'm not hacking anything up!)
After New Year's, I'm going to have Pappaw call his friend so we can set a CONCRETE date for April or May.
For the last 4 years I've been saying "this spring" and it never happens. (2020 has been a mess from front to back not just due to COVID, but for other reasons)
So I'm not making any more promises, but I can say we're going to try to plan things better. I need to drive this car in 2021.
I actually came across the son of the guy who painted it for Pap, on Facebook. He installed the vinyl top himself (though it did originally come with one). Said it was the second top he ever did. And he must be a natural because it came out perfect and still looks good almost 20 years later.
My cars, passed down by my grandfather:
'68 Camaro SS (454/TH400, possible L78/M22) LeMans Blue, black deluxe interior, black vinyl top. 3.73- mostly Day 2.
'89 Mustang GT- 3.55, subframe connectors, muffler delete, and a couple other minor mods. Exactly as he wanted it, so how it shall stay
Also:
1995 Ford F-150 XL
2004 Dodge Ram Hemi GTX- #192 of 433
Ain't no fun in viewing your car as an 'investment'. Get out there and beat on it!
Old 01-03-2021, 09:31 PM
JRC99's Avatar
Who says the youth don't do anything these days? Got a set of Accel plug wires for Christmas, so today my friend Darren and I put em together and put em on. Tomorrow I'm ordering valve covers for it (M/Ts, baby!) and I'll at least see if any valves are loose even though I'm not qualified to fix them.
Why am I doing all this if it just has to be disassembled again? Simple. Morale.
Also:
1995 Ford F-150 XL
The Following User Says Thank You to JRC99 For This Useful Post:
John (01-06-2021)
  #224
Old 01-10-2021, 02:22 AM
JRC99's Avatar
Originally Posted by cook_dw View Post
When you put new valve covers on it make sure to get photos of the casting numbers and dates of the heads!
This is old, I know, but I finally did the valve covers. The heads are 291s.
The date code looks like 12-9. December of 1969 maybe? At least, I think that's the date code. Could be wrong. But they're definitely 291s.
Here it is buttoned up. Still got a couple minor things to do (mainly re-cleaning the plug wires on the driver's side from where I got oil on them and verifying the firing order again (diagrams confused me so dad will help me with it tomorrow) and then I'll fire it up again. There was one loose rocker arm and I'm hoping (but doubting) that was my valve train noise. If not, It's above my skillset- and budget.
But for now, enjoy the pretty!
Also:
1995 Ford F-150 XL
markinnaples (01-11-2021)
  #225
Old 01-13-2021, 04:24 PM
JRC99's Avatar
Just a small update. I fired it for a minute. Sounds like it's got a header leak, but that loose rocker was indeed the issue for the knock. When it gets warmer, I'll change the oil. try to perfect the timing, and motorwise she's good.
Also:
1995 Ford F-150 XL
Old 01-15-2021, 04:45 PM
RogerD's Avatar
RogerD RogerD is offline
Joe,
Michelin radials were around (aftermarket) back then so, “Day 2” acceptable in my opinion
That August day I bought my new 69 Chevelle, I drove away with a set of Michelin radials (just a couple of weeks old, off my 66 Chevelle) swapped by Bill Allen’s shop as part of the deal
Originally Posted by JRC99 View Post
This seems like a good place to introduce myself. I'm Joe. I'm 15 and have grown up a total gearhead. I'm completely in love with Day 2 cars and 70's Street Machines/Street Freaks.
. . . Clearly, It's pretty Day 2 apart from the MSD ignition and Flowmasters (and the radial tires).
The Following User Says Thank You to RogerD For This Useful Post:
JRC99 (01-15-2021)
  #227
Old 01-15-2021, 10:43 PM
JRC99's Avatar
Originally Posted by RogerD View Post
Joe,
Yeah, but to my eyes, nothing looks better than a fat pair of bias plies sticking out a touch past the rear quarters!
Also:
1995 Ford F-150 XL
Old 01-16-2021, 08:56 PM
JRC99's Avatar
Annnnd my knock is back!
Using a stethoscope, it seems to be coming from near the timing cover.
And, it wouldn't be this car if something else didn't also go wrong- the fuel pump is leaking. Great.
That header leak sound, though? Gone. Was either from the wrong firing order, or, something cam related if that rocker arm nut came loose. I'll probably yank the cover again and double check.
EDIT: Cranking it by hand while watching the rotor proves the chain is trashed. I'll start there.
Also:
1995 Ford F-150 XL
Old 01-18-2021, 03:32 AM
WILMASBOYL78's Avatar
Post Noise in timing cover...
The factory nylon gear and crappy chain were an accident waiting to happen. If you can see the wear from watching the rotor, don't wait too long take care of it. Be sure you get a quality double roller steel chain and a new set of gears.
Other items to check are the valve train parts...the big block motors of that vintage were known for 'dropping valves'. The BB springs and hardware were part of the problem...you might want to look at changing out the top end pieces, if time and budget allow. I did it on our 70 TH400 car many years ago...the timing chain fell off into my hand when I took the cover off
I changed all the valve springs, keepers, retainers...installed new valve seals. Reused pushrods and rocker arms, balls and nuts....they looked pretty good. Those 291 heads are the hi-perf units...big valves, rectangular ports...typically meant for high compression like 11 to 1.
Good luck with the car...
-wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 01-19-2021, 12:12 AM
JRC99's Avatar
-wilma
Most, if not all of the valve train, is probably Comp Cams at this point. It had a 305H installed at some point in the 80s and I'd imagine the pushrods and springs were done too.
As for the chain, it's definitely getting done sooner rather than later.
Also:
1995 Ford F-150 XL
