#971
Re: Ryan Weaver's 1969 Olds Cutlass S W31 Club Coupe
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 300deluxeL79</div><div class="ubbcode-body">seal up the firewall/floor holes, make it difficult for the little buggers to get in the body </div></div>
Will do!! Ryan
1969 Beaumont 350 Auto White Sold 1969 Beaumont 307 Auto Green Sold 1969 Chevelle SS 396-L35 Auto Blue Sold 1969 Oldsmobile Cutlass 'S' Sports Coupe W31 |
#972
....also a mean hungry cat!
#973
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: earntaz</div><div class="ubbcode-body">....also a mean hungry cat! </div></div>
I AM LEAVING THIS ONE ALONE......NOT GOING THERE. Dan
69 300 Deluxe Post Sedan Frost Green 69 SS396 300 Deluxe Post Sedan Lemans Blue SOLD 70 Buick Skylark Post Sedan Gulfstream Blue 70 Buick Skylark Post Sedan Burnished Saddle http://m.youtube.com/watch?v=PM3DE8qI2NY https://m.youtube.com/watch?v=Yn4xEmGypUw |
#974
Very mature.....are you feeling ok?
:-) Ryan
#975
My M20 is being restored by Fellow sYc alumni Nick Morocco:-)
Nick picked up the Trans at MCACN and sent a few pictures as he starts inspecting it. "Ryan, I started the disassembly of your Muncie and wanted to share some pictures with you. This may take a couple of emails to send them all so there may be some additional emails. There are a couple of issues you will see in the pictures. They are: · The tail shaft has been welded on where the drive shaft yoke goes in. Looks like a rear U-joint may have broken causing the drive shaft to whip around. If that is the case, you may see some signs of that on your floor boards. The other possibility could be the drive shaft is too long causing the yoke to be pushed too far as the suspension flexes. Please chek for this at final assembly. You need about ¾ to 1 inch travel from where the yoke is bottomed into the trans and the rear U-joint needs pulled into the differential yoke. · 4th gear shows a lot of synchro teeth wear as does 1st gear. First gear could be attributed to clutch adjustment and 4th gear to driver. 2nd and 3rd look surprisingly better that 1st and 4th. Go figure. · The side cover “inside” arms are the weakest arms ever made. You can see that in the pictures. Just a small connection point from there are forks attach on the inside and the outside arms attach. The outside threads are also 5/16 studs which is also a weak point. We have a few options we can talk about before assembly. Nick Morocco"
#976
#977
I have been looking into clutch linkage:-) Olds guys say GH is correct:-)
Have a bracket coming for the brake distribution block as mine was moved on top of the frame for header clearance. Ryan
#978
The bracket is an easy find, but first check with Al Stager. He may have the bracket?.....You are fortunate to have the correct Z-bar and adjuster.....as originals are very difficult to find.
#979
Good point I will check if Al has any loose items floating around:-)
An Olds guy offered the bracket for free, just shipping cost:-) (So many people have jumped in to help me out!!!!) I really appreciate all the support!!! Ryan
#980
BTW....your box of parts arrived yesterday [img]<<GRAEMLIN_URL>>/headbang.gif[/img]
