Old 05-26-2012, 02:12 AM
Super_Z28 Super_Z28 is offline
Default Protecto-Plate Forgery ???
I have a 69 Camaro and Ive been searching how to authenticate the protecto-plate with no luck ... Millions of pics of forged and repo's but no solid info on how to tell the difference ... Anyone know some solid tell-tale signs to spot an authentic over a fake ???
Old 05-26-2012, 03:26 AM
Lynn Lynn is online now
Default Re: Protecto-Plate Forgery ???
There are a few guys on here who can tell. Kurt S and Mark C come to mind.
When I suspect a fake, I usually look up the address and see if it is even a real address. Amazing how many will be the middle of a lake, or in an industrial area. The fakers don't want to use a real address. It is too easy to check county land records and see who owned the home in 68 or 69.
Good luck.
Old 05-26-2012, 11:39 PM
Thats where were headed .. Address exists but trying to verify homeowner ...
Old 05-27-2012, 01:11 AM
iluv69s iluv69s is offline
at the county hall of records for the address on the protectoplate, you should be able to pull the current owner deed for that address and trace back from there to find the prior owners of the property. each deed will usually have some kind of verbage that says more or less the following...." being the same land and premises conveyed from john Doe to Joe Smith on Dec 25, 1969 in Deed Book 1234 page 326." Many deeds now can be pulled on-line on the county websites !! But most websites only go back so far..not to the 1960's... If not, you may be able to hire a title searcher to do this for you..they are specialists and will charge a small fee, but very reasonable... Good Luck !!
Old 05-27-2012, 01:18 AM
Best is to post a good pic here and the experts will let you know.
Old 05-27-2012, 12:31 PM
Is this POP for the '69 you mentioned as having McNeish blessings in your previous postings here?
[img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
Old 05-27-2012, 07:25 PM
Stefano Stefano is offline
Reproduction POP have been big business for over two decades.
Some repros use original blanks, stamped from original machines, as well as original tape and glued to original vintage warranty booklets.
Bottom line is that it can be very difficult to tell a repro from real!
Most repro POPs which I have seen, had the correct owner info as well as VIN, but other pertinent engine, trans and rear codes had been changed.
Click to visit the Nickey Performance Facebook--&gt;
Old 05-28-2012, 12:32 AM
scott s scott s is offline
Thats if the p.o.p was in a private parties name,i have several that were in a business name or a company.....etc
Old 05-29-2012, 12:38 PM
William William is offline
Check out this side by side comparison of real vs repro.
http://broachbuster.com/id4.htm
Old 05-30-2012, 05:52 PM
restore-z28's Avatar
restore-z28 restore-z28 is offline
There are some good suggestions in this post that should give you some ideas on how to do more investigation on the original owner. Also noted was how difficult it is to spot a fake versus a real one. Agree with you posting some pics and soliciting feedback.
1970 Z28 Camaro
