Old 05-13-2020, 12:12 AM
nova67 nova67 is offline
Default Camaro firewall insulation
Does anyone have any tips for installing the rubber retainers for the firewall insulation? The retainers seem to be a bear to get in without ruining them.
Attachments - The Supercar Registry Trim tool.jpg Trim Tool 1.jpg Gen 3 Insulation.jpg Firewall pad fastenersw.JPG
Old 05-13-2020, 12:39 AM
I am sure there are a few ways of doing it, but this is how I do it. Get a Phillips screwdriver, and push that into the retainer to stretch it. Also put a smear of grease or silicone on the rubber part going through the firewall. Don't push too hard with screwdriver or it will poke through. Guess if you have an old Phillips you could round off the tip.
- Warren
The Following User Says Thank You to WorkinProgress For This Useful Post:
X66 714 (05-13-2020)
Old 05-13-2020, 01:48 AM
X66 714's Avatar
X66 714 X66 714 is offline
I've had good luck with Dawn dish soap to make them slippery....Joe
Old 05-13-2020, 03:06 AM
I ground down the end of an old cheap phillips screwdriver to make it a smooth dome, so there was no point.
Old 05-13-2020, 04:06 AM
169indy's Avatar
169indy 169indy is offline
One of the most important things to remember is the need to push in two planes; push inside the tip and at the flange at the same time.
Fashion a Tool as fancy as this brass custom tool or even machine or grind down a screwdriver so it performs in the same manner.
Use: Isopropyl alcohol, Silicone Spray lube or Dish-soap, something to lubricate the installation.
I think it also 'depends' which version of the fastener you have, I have seen very brittle plastic version -vs- a more rubbery flexible style,,,,
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 05-13-2020, 04:58 AM
Kurt S Kurt S is offline
Factory used dish soap, fwiw.
Kurt S - CRG
The Following 2 Users Say Thank You to Kurt S For This Useful Post:
Bill Pritchard (05-14-2020), X66 714 (05-13-2020)
Old 05-13-2020, 12:00 PM
70 copo 70 copo is offline
Each worker in the trim shop had a tool box and an apron with front pockets for tools also.
Old 05-13-2020, 04:56 PM
Default firewall fasteners
I have the good rubber fasteners. will grind down an old philips today and give it a try with the dish soap. Thx for the help. Tom
Old 05-13-2020, 06:23 PM
jl8z28 jl8z28 is offline
If you bought one of those cheep insulations they are a pain and don't line up the molded ones fit great and easy to install
Old 05-13-2020, 08:20 PM
Default firewall insulation
I do have the molded insulation. Tried to put fasteners in today and broke 2 even using the soap screwdriver method . Have to order more fasteners.
