Old 06-10-2019, 12:24 AM
The way I understand it the high HP cars got the larger yoke for the 1330 U joint and used U bolts instead of straps.
Old 06-15-2019, 07:43 PM
R68GTO R68GTO is online now
Bare, naked BE!
1969 427 COPO Camaro Lemans Blue/Black, M22 4 speed, 15,500 original miles
The Following 3 Users Say Thank You to R68GTO For This Useful Post:
big69fan (02-10-2020), JBALL (07-30-2019), Xplantdad (06-15-2019)
  #153
Old 06-16-2019, 03:29 AM
Please don't take anything out of that rear end without measuring backlash and doing a pattern check on it first. Once you remove parts it's too late to do this and you will have no idea how to set it up again. Also, please do not put punch marks on the left bearing cap and only put one mark on the right cap. Those punch marks can make the cap weak and the left cap carries more of a load than the right one. If the factory paint marks are still on the caps then there is no need to put punch marks on either cap, and even if the caps get mixed up you can still figure out where they go by measuring the bore size.
It looks like that housing is in great shape. Those tubes look like they are free of rust pits and the spring perches look like they haven't been bent or torn from abuse.
PeteLeathersac (06-16-2019)
  #154
Old 06-16-2019, 03:51 PM
Does this rear end have the 1330 yoke with U bolts?
Old 06-16-2019, 09:34 PM
Spring perches are not original to the rear, Frank A. had his guy weld them on as part of the deal when I bought it. Housing and tubes are in fantastic shape with almost 0 pitting. It does not have the correct yoke...William over on CRG says that it should be the larger yoke (3954393) with straps/bolts instead of u-bolts.
big gear head (06-16-2019)
  #156
Old 07-19-2019, 12:49 AM
Stopped to visit the car. Bodywork and initial panel alignment is coming along well. Currently waiting on my hood hinges to get back from resto so the hood can be aligned/fit. Original cowl hood was near perfect - zero rust. They will be protecting/retaining all the factory original interior overspray including the little paper tag on the inside of the door frames and rear panel inners. They will have to blend a little LB on the jamb side of the door inners where the PO sprayed some black.
The Following 9 Users Say Thank You to R68GTO For This Useful Post:
big gear head (07-19-2019), Copo_Cartel (07-19-2019), Crush (07-19-2019), dykstra (12-09-2021), JBALL (07-30-2019), Nasblu (10-28-2021), PeteLeathersac (07-19-2019), ScottG (08-14-2019), ZLP955 (07-19-2019)
  #157
Old 07-19-2019, 03:51 AM
enio45 enio45 is offline
any possibility of getting a pic of the rear axle tube stamping pls?
Eddie M
MBTMF
68 COPO Camaro 9737 non-converted YENKO
69 YENKO SC Camaro, Hugger Orange - born with engine!
Old 07-19-2019, 11:28 AM
ZLP955's Avatar
ZLP955 ZLP955 is offline
Looks great!
Tim in NSW, Australia
The Following User Says Thank You to ZLP955 For This Useful Post:
R68GTO (07-19-2019)
  #159
Old 07-19-2019, 10:23 PM
Eddie, here's a pic of of the stamp on my axle.
The Following 6 Users Say Thank You to R68GTO For This Useful Post:
Copo_Cartel (07-20-2019), enio45 (07-20-2019), JBALL (07-30-2019), m22mike (07-20-2019), PeteLeathersac (07-19-2019), ZLP955 (07-20-2019)
  #160
Old 07-20-2019, 11:35 PM
Copo_Cartel's Avatar
I have the same date in my Copo
