Old 09-29-2020, 12:51 PM
X66 714's Avatar
X66 714 X66 714 is offline
Default spatter paint
Has anybody used this product? Opinions? The body shop purchased it for my 69 Camaro...Thank you, Joe
Attachments - The Supercar Registry trunk floor 2.JPG trunk floor 1.JPG spatter.JPG DF934644-1832-4AB5-8C1A-3DE3C821F6AC.jpg
Old 09-29-2020, 01:16 PM
Have you opened it up to see how it mixes and what the particles float like Joe. I got a quart of the stuff Heartbeat sells and I'm going to open it here in the coming days to see what it's like. In a few weeks, we'll spray it out and test it through a shutz gun before we put it to use.
Curious if the two products look alike in the quart can.
L79Chevelle (11-02-2020)
Old 09-29-2020, 02:21 PM
X66 714's Avatar
Haven't looked yet. The can says do not shake but to gently stir. It also says to shoot a base colour first...Joe
Old 09-29-2020, 08:25 PM
L16pilot L16pilot is offline
I have not used The Parts Place product, but have used Zolatone which I believe is very similar. Takes some practice getting the gun set up and the results were so-so. Better than the aerosol trunk spatter paints, but ended up doing a two-stage process of applying the base first in epoxy followed by a separate application of the aqua spatter using single stage urethane. Took a couple of hours experimenting with pressures and technique for the spatter and ab out a minute to do the actual application. For clarification, mine is a Norwood car that has more of a droplet appearance than the LA stringy appearance. IMO, well worth the time and effort to do the two-stage process.
Steve Nuwer
1970 Z28, Norwood 03A, 48 48, 723 Int, M20, COO, 2021 Legends Platinum restored
1970 L78, Norwood 04C, 17 17, 711 Int, M21, COO, born-with drivetrain project.
1972 Z28, Norwood 11C project, born-with drivetrain, 26 26, 775, M20, CGG project
1970 Z28, Norwood 05C, 48 G, 720 Int, M21, COZ, Original Unrestored (SOLD)
www.2ndGenZ.com
The Following 4 Users Say Thank You to L16pilot For This Useful Post:
BCreekDave (09-29-2020), m22mike (09-29-2020), Woj (10-01-2020), X66 714 (09-29-2020)
Old 09-29-2020, 10:35 PM
Pictures? C'mon Steve.
Owned since 1978 - First Car
Old 09-29-2020, 11:15 PM
Here ya go Dave. As a side note, I used the original unrestored trunk finish in my 05C Norwood car to duplicate efforts in my 03A Norwood project. In doing so, the "Black" appears to be a very dark gray, so I mixed the SPI epoxy base to match...then worked on the setup and my technique to approximate the spatter size and density.
Steve Nuwer
www.2ndGenZ.com
BCreekDave (09-30-2020), CamarosRus (10-03-2020), Woj (10-12-2020), X66 714 (09-29-2020)
Old 09-30-2020, 01:47 AM
Billohio Billohio is offline
My Z has the dark epoxy base coat and then the gun was set up to spit an aqua spatter. Turned out great
Picture makes it look metallic! Looks better in person
Bill
The Following 5 Users Say Thank You to Billohio For This Useful Post:
CamarosRus (10-03-2020), L16pilot (09-30-2020), NorCam (10-02-2020), randy27 (09-30-2020), X66 714 (09-30-2020)
Old 09-30-2020, 11:19 PM
randy27 randy27 is offline
That looks good! We will be working on buddy's Z soon after we finished installing the shocks and m/t tires on the current Wrangler project. Bet he'll that combination of epoxy base coat and aqua spatter for the Z.
Old 10-02-2020, 02:12 AM
I found a picture of the can of green used on mine. It is PPG shopline code 43816. Looks a bit minty on the can. On top of the dark base it doesnt look very green
Picture is of the paper used to cover what was not painted
Bill
The Following User Says Thank You to Billohio For This Useful Post:
X66 714 (10-02-2020)
Old 10-11-2020, 12:32 PM
Danzo Danzo is offline
Anyone try this?
https://www.ebay.com/itm/Guru-Colors...EAAOSwgbhaTSK6
