Old 07-14-2019, 07:16 PM
scuncio scuncio is online now
Default '67 4-piston caliper pad rattle
I have a persistent issue on my '67 disc-brake GTO - I get a regular clicking noise from either one or both pads as they rock inside the caliper. Is there any sort of anti-rattle spring, washer, etc that is supposed to be here to avoid this? The noise goes away completely when I apply the brake. Thanks!
Old 07-14-2019, 08:06 PM
----Tony,,, No disrespect but whose pads are they? If they are a bit off as is somewhat typical of offshore pads they tend to do what you are describing. There is no anti rattle springy thingy that I know of. When you apply the brake you are forcing the pads to one end and they stay there till you let off the brakes and apply throttle. Then they are going slightly back and forth and they rattle because they have too much clearance on both ends. Get the best US made pads you can find and see what happens. Hope this helps...….Bill S
Old 07-14-2019, 09:56 PM
Bill, no offense taken. These were the pads that came in a ziploc bag when I bought the car (the original owner had taken the calipers off to have them sleeved, and bought new pads as well). I’ll look into a good set of pads and see what happens. Thanks!
Old 07-14-2019, 10:35 PM
67 Nova Boy's Avatar
How are the pins that hold the pads on? The repos are smaller in size {dia wise} and that may adding to the rattle as well.
Dave
67 Nova Boy
Old 07-15-2019, 02:30 AM
Bought a NOS set of pads - I'll report back when I install them. Thanks!
Old 07-15-2019, 02:31 AM
Dave
67 Nova Boy
Pretty sure they are originals. Thanks Dave!
Old 07-26-2019, 02:23 AM
Issue is basically gone.
What are you guys doing to break in old Delco organic pads?
Old 07-26-2019, 03:34 PM
----Shutdown at Milan,,,LOL!!!......Bill S
L_e_e (07-26-2019)
