Old 03-20-2022, 11:02 PM
Mark2002 Mark2002 is offline
Default 1969 L78 4:56 gear
Hello, new member here, I've been reading the forum for a while and just joined.
I have a 1969 Chevelle L78 4 speed originally Butternut yellow. Black top, black interior.
My build sheet has a KM code which matches the stamp on the rear for a 4.56 gear. All the sources I can find on the web point to only one 1969 Chevelle ordered with this rear end ratio. Does anyone else out there have a documented factory 4.56 rear in their car?
Thanks
The Following 9 Users Say Thank You to Mark2002 For This Useful Post:
big gear head (03-21-2022), combinefixer (03-21-2022), cruiserofland (03-21-2022), HuggerSS (03-20-2022), olredalert (03-21-2022), PeteLeathersac (03-20-2022), ruralrte66 (03-21-2022), SS427 (03-21-2022), YenkoYS-199Stinger (03-21-2022)
Attachments - The Supercar Registry IMG_4712.jpg IMG_4710.jpg IMG_4709.jpg IMG_4705.jpg
Old 03-20-2022, 11:17 PM
TimG TimG is offline
Wow, I’m no Chevelle expert, but I’m anxious to hear about this question.
Old 03-20-2022, 11:34 PM
There was a Black '69 Hardtop factory 4:56 car we looked a here a few years back.
Factory 4:56 is special as some info indicates Copo 9511 was necessary for '69 model cars.
Looking forward to seeing/hearing more about your car, welcome aboard!
Old 03-20-2022, 11:41 PM
Jerry B. Garnet Red '69 L-78 Chevelle has a factory 4.56 rear....not a COPO.
Old 03-21-2022, 12:51 AM
1967 4K's Avatar
1967 4K 1967 4K is online now
Default Jerry B.
Yep and Jerry has the build sheet on his car.
Richard
1967 Camaro SS 396/375 4K
Old 03-21-2022, 03:05 AM
combinefixer combinefixer is offline
My build sheet has a KM code which matches the stamp on the rear for a 4.56 gear. All the sources I can find on the web point to only one 1969 Chevelle ordered with this rear end ratio. Does anyone else out there have a documented factory 4:56 rear in their car?
Thanks
Which transmission does this beast have?
134379 L78 M22 in 61 61
Old 03-21-2022, 12:45 PM
The build sheet has a XF code crossed out and XD written in. Seems strange that they would replace an M21 with another M21 code. A friend suggested to me that perhaps it was meant to be replaced with a M22. The transmission is in the car, so I haven't been able to verify the shaft or the angle on the gearing to confirm it as an M21 or M22.
I have not driven it yet which would make it much easier to tell which trans.
Unfortunately, it no longer has the original motor. The sheet metal appears to be all original and in great shape. Surprisingly for a NJ car, it has original quarters rockers and fenders. Floors and trunk are also very good. I'll post some pictures soon.
The Following 5 Users Say Thank You to Mark2002 For This Useful Post:
big gear head (03-21-2022), chevyman0429 (03-21-2022), combinefixer (03-22-2022), cruiserofland (03-21-2022), olredalert (03-21-2022)
Old 04-12-2022, 05:29 PM
The trans change was probably related to the driven gear in the trans speedo bullet. They had to get the speedo to the correct speed based on the rear ratio, the driven gear on the bullet, and whether or not a Stewart Warner reducer was needed.
ScottG (04-23-2022)
Old 03-21-2022, 03:02 PM
tunes's Avatar
tunes tunes is online now
Welcome to this site and I'll look forward to seeing pictures and hearing more about your L78.
Robert
_______________
2023 Stingray Coupe Z51
Old 03-21-2022, 04:38 PM
Welcome Mark and DO TELL! Lots of pictures too!
