Old 04-26-2011, 03:30 PM
Supergas990 Supergas990 is offline
Default Distributor Rebuild
Can someone help me please. I belive that I need to rebuild the distributor in my 1967 Chevelle 327. Specifically, I'm trying to find someplace that stocks the replacement shaft bushing for a stock distributor.
Thanks in advance.
Blair
1968 L71 Corvette Coupe
1967 L30 Chevelle Malibu
1968 L79 Corvette Convertible (son's)
Old 04-26-2011, 06:11 PM
Default Re: Distributor Rebuild
What makes you think you need to rebuild? Symptoms? Is it a stock distributor that originally came with the car? If you have a part # the part should be available - at least on ebay.
Old 04-26-2011, 07:32 PM
Completed the car last week and finally got it out driving. Original distributor was convereted with a mallory kit. When the driving the car it occassionally sputters or sounds like it misses and lugs. Also, the tach flutters when this is happening. These items just seem linked to the ignition and distributor to me.
Since everything else is new and the distributor is 44 years old, it seems like a good place to start. I didn't do anything to it, but clean it up during the restoration of the car.
I'm open to suggestions for other places to look though.
Blair
Old 04-26-2011, 09:43 PM
I recommend Harvey Edelstein here in Glen Ellyn Il. 630-469-6747.
Harvey offers a distributor rebuilding service for point distributors as well as unitized and transistorized ignition systems.He also stocks many GM distributors by original equipment part numbers,which he sells on an if he has,then exchange basis for it only.
Old 04-27-2011, 11:39 PM
<span style="font-weight: bold"><span style="font-style: italic">&quot;Original distributor was convereted with a mallory kit.&quot;</span></span>
Are you saying that the distributor is a Mallory (which model, dual point, vac advance,etc.?) or does it have some internal Mallory pieces on a stock GM distributor? What coil are you using? Mallory parts are fairly readily available and it is a relatively simple process to rebuild one.
Old 04-27-2011, 11:59 PM
napa68 napa68 is offline
We need NJ Steve to document a rebuild. Anyone could do it then! [img]<<GRAEMLIN_URL>>/scholar.gif[/img]
Old 04-28-2011, 12:05 AM
CONCUR!
Old 04-28-2011, 03:55 PM
Stock housing, shaft, cam, advance, vaccum module, etc... Mallory electronic conversion kit.
Old 04-28-2011, 05:41 PM
Call Harvey at the number I posted above,or cell# 630-254-3656..he can help.
Old 04-29-2011, 04:41 AM
Trying simple things first, like disconnecting the tach and see what happens. I had something similar happen a few years ago and it was the tach causing the problem. It's the old K.I.S.S. system.
