Old 11-06-2019, 03:35 PM
Starship Starship is offline
Default NOS 1967-1969 Z28, 1970-72 Corvette LT1 Oil Pump
______________________________________________
NOS GM Special High Performance Oil Pump Assembly Part #3848907 in the original box. This is a high volume that came factory in1967 and 1968 MO code, and 1969 DZ code Z28 302 cu. in. Camaros with solid lifter camshafts. Correct for 1970-72 Camaro Z28 and Corvettes with LT1 350 engines with solid lifters. Correct for 1963-64 Corvette 2nd design and 1965 Corvette 327 FI with mechanical lifter special H/Per engines. Correct for 1964 Chevrolet passenger cars 409 with 2x4 BBL carbs special high performance. $250.00 plus shipping.
Old 11-06-2019, 04:18 PM
luzl78 luzl78 is offline
I’ll take it. Jeff in nj
The Following User Says Thank You to luzl78 For This Useful Post:
Starship (11-07-2019)
Old 11-06-2019, 04:22 PM
Any physical measurement differences on this pump versus a standard small block pump? My understanding was it just had a higher pressure white stripe spring. Can anyone verify this? Thanks.
Owned since 1978 - First Car
Old 11-06-2019, 05:52 PM
PM sent Jeff.
Old 11-07-2019, 12:34 PM
SOLD Thank you
