Old 12-30-2019, 04:34 AM
grantprix's Avatar
Originally Posted by scuncio View Post
Amazing car, great thread! Just curious, do those torq thrusts rub on the front fender wheel openings when turning?
Thanks! Well, I really cant answer that since I haven't driven the car with those wheels which are currently off of the car. I plan to run the original steel wheels with new rubber when I get to that point. I may run the torq-thrusts again down the road after I get them cleaned up and new tires, I do like how they look on the car.
Old 01-23-2020, 11:58 PM
grantprix's Avatar
Default Very close...
Just about ready to fire it up. I just got my restored and correct "768" stamp number/dated alternator from Ken Bruno installed. Primed the engine again yesterday while checking oil pressure with a manual gauge, got an instant and consistent reading of 62 lbs each time. Got the distributor dropped in and then pulled the plugs to blow out the Marvel Mystery oil that has been in there for months. The engine turned over smoothly with no odd noises. After testing the original spark plug wires, I decided to buy a new set of repro's. Half were within spec, half were not and the one #7 wire that had been replaced was dead. New ones should be here next week. Also got the new vacuum hoses ran today. Anyway, hope to have it running next weekend if all goes well!
The Following 7 Users Say Thank You to grantprix For This Useful Post:
Arrowsmith (01-24-2020), bergy (01-24-2020), napa68 (01-24-2020), olredalert (01-24-2020), PeteLeathersac (01-24-2020), Tenney (01-24-2020), Xplantdad (01-24-2020)
  #53
Old 01-24-2020, 01:23 AM
Looking good!
Old 01-24-2020, 02:53 PM
----Grant,,,I don't recognize the contraption on the right rear of the intake with all the green stripe vacume (sp) lines going to it. Is that California only, and what does it do?......Bill S
Old 01-25-2020, 11:11 PM
grantprix's Avatar
Bill... that's correct, the '67 CA cars with manual trans and A.I.R. were the first to use this valve together with a dual port vacuum advance that both advances and retards timing. It was also used on '68s and some '69 applications. Not sure exactly how it functions, but I hope it all works!
Old 01-26-2020, 07:12 PM
grantprix's Avatar
Bill... this is from my service manual and explains how the valve functions.
The Following User Says Thank You to grantprix For This Useful Post:
olredalert (01-26-2020)
  #57
Old 01-26-2020, 08:33 PM
----Wow, Grant! At least you had almost all of the smog stuff still on the car. The 67 California delivered 442 I bought years back now (not my Mass. delivered 67 W30) had roughly half to a bit less than half of the smog parts in the trunk when it was delivered. Me, wanting to do the right thing, started looking for the missing stuff. That turned out to be just about impossible. I had almost given up when that car got caught up in a shop fire I had (not my fault) and that ended the search...….Bill S
Old 01-26-2020, 09:54 PM
grantprix's Avatar
Bill... yes, I was amazed to see it was all intact when I first saw the car. I just hope it all works as it should, good used or NOS parts for these systems are difficult to find. Sorry to hear about that CA 442. I don't recall you telling me that story before, what a shame.
Old 01-27-2020, 03:00 PM
----Most of the time I try to forget the fire as I lost two cars and my Suburban, all with no insurance (just no fire and theft on the Subby). Learned quite a lesson that day...….Bill S
Old 01-29-2020, 03:33 AM
Mallard Mallard is offline
Great looking car. My sister's 2nd ex-husband has (or had, not sure if he still does) the same colour gold '67 goat. His was two tone with a black non-vinyl roof, with power steering and no power brakes, red line tires with hub caps. He bought it from someone in the state of Washington but I don't believe it had the AIR pump on it though. I haven't seen the car in nearly 20 years but he seldom drove it and back then it was mint so I presume it still is.
