Old 09-12-2019, 11:04 PM
Default Carburetor ID help
I stopped at a yard sale today and picked up 2 carburetors. I think one of them is a 429 Cj Rochester Q Jet, but not sure. I have no idea what the other one is. It's a Rochester and it looks like a 4G, but not sure. the tag has holes punched in it and the last number is punched out. Any ideas?
Attachments - The Supercar Registry 20190913_200436_resized.jpg 20190912_201053_resized.jpg 20190912_201011_resized.jpg 20190912_200955_resized.jpg
Old 09-12-2019, 11:48 PM
John Brown's Avatar
John Brown John Brown is online now
There were four different number Q-jets used on 70 429 Fords. The part numbers ARE NOT the same as the tag or stamp numbers. That carb is worth major $$$$. Q-jets were only used on Cobra Jet 429's. The four possibilities depend on,
1 Auto and no air conditioning
2 Manual and no air conditioning
3 Auto with air conditioning
4 Manual with air conditioning.
I have in my grubby little mitts the Rochester Products bulletin 9C-7000, which lists all four carbs by their given parts numbers, and the individual parts they are made up of, but doesn't tell you which on you have in hand. Maybe this link will help decode the Ford tag and identify it. Good luck. If you need a copy of the Rochester sheet, I would be glad to mail you a copy.
http://www.429mustangcougarinfo.50me...new_page_6.htm
John Brown
big gear head (09-13-2019)
Old 09-12-2019, 11:54 PM
John Brown's Avatar
Freddie, is the Q-jet stamped with a number on the drivers side, above the secondary throttle shaft, on the main body? If it is, that will make decoding it much easier.
John Brown
Old 09-13-2019, 12:00 AM
John Brown's Avatar
1 7040288 auto no air
2 7040287 manual no air
3 7040286 auto with air
4 7040285 manual with air
John Brown
The Following 2 Users Say Thank You to John Brown For This Useful Post:
big gear head (09-13-2019), Xplantdad (09-13-2019)
Old 09-13-2019, 12:48 AM
x77-69z28's Avatar
I used to work for Ford. The DOOF decodes to 70 Torino. That’s all I got
Buddy
The Following User Says Thank You to x77-69z28 For This Useful Post:
Old 09-13-2019, 01:42 AM
I should have posted this earlier. Thanks for the replies. Both carburetors seem to have a few pieces missing.
Old 09-13-2019, 03:09 AM
John Brown's Avatar
Q-jet appears to have been built December 8, 1970. Since the Mustang / Cougar site says those carbs were used in 70 and 71, the stamped date makes it a 71 carb.
John Brown
Old 09-13-2019, 11:43 AM
Thanks for the help. Any idea what the other one is?
Old 09-13-2019, 11:51 AM
John Brown's Avatar
A picture of the drivers (left) side showing the throttle arm would be helpful.
John Brown
Old 09-13-2019, 01:07 PM
OK. I'll try to get that later today.
