Old 03-19-2019, 07:10 PM
madden madden is offline
Default Deuce fuel filter
hi guys
sorry but need some help again with my car
just about ready to fire up the deuce after freshening up the engine/ trans
besides the fuel filter sock on the tank sending unit......what is the correct inline filter for the yenko deuce? and where would it be located?
any part number or pics i can go by
thanks again for your help
regards
chris
1970 citrus Yenko Nova
Old 03-19-2019, 07:26 PM
frankk frankk is offline
I believe should only use the two sintered bronze filters in the carb inlets
The Following User Says Thank You to frankk For This Useful Post:
madden (03-20-2019)
Old 03-19-2019, 09:08 PM
What Frank said. Two bronze filters, one for each float bowl. Remove the 1'' fitting and install the filter. I believe there is a spring also installed in each float bowl. Spring first then filter...
madden (03-20-2019)
Old 03-20-2019, 12:48 AM
hi
yes.......those are already present in my holley carb
no other "PRE" carb inline filter is required or original to the deuce?
thx
chris
Old 03-20-2019, 03:52 AM
The gentlemen above are correct. Nothing else.
The Following User Says Thank You to Schonyenko2 For This Useful Post:
madden (03-20-2019)
Old 03-20-2019, 12:01 PM
ok guys
thank you so very much
you guys are great
regards
chris
Old 03-20-2019, 02:14 PM
You may want to consider the temporary install of an inline filter just in front of pump in the rubber hose. If you have a new tank there may be some leftover residue that this would catch rather than clog the carbs filters.
Owned since 1978 - First Car
The Following User Says Thank You to BCreekDave For This Useful Post:
madden (03-20-2019)
Old 03-20-2019, 04:22 PM
earntaz earntaz is offline
Thin gasket also on fitting side of filter?
Old 03-20-2019, 04:57 PM
Correct
