Old 10-21-2019, 11:10 PM
ZiggyL78's Avatar
ZiggyL78 ZiggyL78 is offline
Default Wtf gm
I'm detailing my L78 Nova. I installed the original style fan and noticed when I put it back together that there was a plate made up that bolts to the rad support and the fan shroud. I figured the previous owner had made this up and I was going to get the right part as it looks Mickey Mouse. I was shocked when my parts guy told me it was the right part from GM. I'm going to make something up that looks more professional. I'd like everything to look stock but there is know way I'm going with this plate. I think only a Nova Guru will notice the difference. Was every Nova BB done this way?
Thanks
Real Canadian Rock
https://www.youtube.com/watch?v=Zdeo-i6uw5g
Attachments - The Supercar Registry nova_shroud.jpg 56201122_2546279535599356_2096953508086415360_n.jpg
Old 10-22-2019, 12:06 AM
Mr. Chevy's Avatar
Yes, that bracket was factory if it is the top one that has the bends in it.
Rich
Old 10-22-2019, 12:19 AM
68 Chevy II 68 Chevy II is offline
The fan shroud should hide the mounting plate
when it's bolted up.
Like Rich said that's how they were on 69-70 big blocks
Tony
Old 10-22-2019, 12:31 AM
YENKO DEUCE REGISTRY's Avatar
It's factory....
Marlin
The Following 2 Users Say Thank You to YENKO DEUCE REGISTRY For This Useful Post:
John (10-22-2019), ORIGLS6 (10-22-2019)
Old 10-22-2019, 04:26 PM
Diamond_Don Diamond_Don is offline
Here's another view. Also while you are detailing, I have two big block top radiator hoses - that I believe are original - and notice that the hose numbers face away from the front of the engine bay. The repro hoses I see have these numbers facing forward.
Good luck!
Old 10-22-2019, 09:19 PM
I still have the original radiator hoses on my unrestored L34 Nova. The top hose part number is facing the engine, which is correct. I see what you are talking about by looking at Marlins green Nova. I'm sure all the repops are this way... They can't even get that right.
Diamond_Don (10-22-2019)
Old 10-23-2019, 05:37 PM
ZiggyL78's Avatar
Not on mine.There is about 2" showing. I can't see any possible way the plate could be covered.
Thanks Tony
Real Canadian Rock
Old 10-23-2019, 05:50 PM
ZiggyL78's Avatar
OK. I have the car back together. I left the spacer off as someone said. The repo fan sits about 3/4s of the way into the shroud and has about 2 1/4" clearance between the fan and rad. I drove the car and I can barely here the howl. I'm 70 in May and my hearing is going. The last L78 Nova I owned was over 20 years ago and my hearing was much better
Thanks to all who posted.
Ziggy
Real Canadian Rock
