Full concourse restored original front end sheet metal hardware kits
All hardware is factory original assembly line installed pieces. No aftermarket or NOS. All period correct head markings and finishes. Kits will be made specific to year and body.
The following is a breakdown of applications in a typical kit: 1. Hood hinge to hood mounting bolts 2. Hood hinge to fender mounting bolts. 3. Fender to upper cowl mounting bolts. 4. Fender to firewall mounting bolts. 5. Fender to door jamb mounting bolts. 6. Fender to lower cowl mounting bolts 7. Fender to radiator support mounting bolts. 8. Wheel well to fender mounting bolts. 9. Wheel well to inner fender mounting bolts. 10. Wheel well to radiator support mounting bolts. 11. Battery tray mounting bolts. 12. Radiator mounting bolts. 13. Fan shroud mounting bolts. 14. Voltage regulator mounting bolts. 15. Horn relay mounting bolt. 16. Windshield washer bottle mounting bolts. 17. Radiator support junction block mounting bolt. 18. Firewall conduit mounting bolts. 19. Accelerator lever pivot hardware 20. Heater box mounting hardware. 21. Windshield wiper motor mounting bolts. 22. Ground strap mounting bolts. 23. Engine harness to firewall block bolt. All hardware is restored to concourse level quality. We start out with original pieces which are chemically cleaned to prep for the plating process . Each is then visually inspected to insure there is no pitting, rounded corners or stripped threads. Any pieces that don't meet these standards are discarded. From there each piece is plated as called for per factory specifications. Kits are $500 plus $20 to fully insure and ship to the lower 48 via Pay pal friends and family. Kits will be made for specific applications such as: 67-69 F-body Camaro/Firebird 68-72 Nova 65-69 A-body Chevelle GTO 442 70-72 F-body Camaro/Firebird 70-72 A-body Chevelle GTO 442 Kits will also be made for other applications upon request. This first kit is for 70-72 Camaros, Chevelles and Novas (only a few bolts need to be changed for specific applications). Keep watching this thread as it will be updated with new kits regularly. |
Pics 1
Pics 2
Pics 3
All kits are bag tag labeled add packed for shipping.
hardware kit..
Impressive attention to detail
The Following User Says Thank You to WILMASBOYL78 For This Useful Post: | ||
Enoch (03-11-2019) |
Rich,
These kits make it nice & EASY! I wish I needed them but I have already acquired pretty much alot of the bolts already and even some from you. Thanxs for selling smalls for they are very much needed and often overlooked.
67 Z/28 Butternut Yellow 69 Z/28 Rally Green 69 Z11 Pace Car (2) 69 RS/Z28 Lemans Blue / Olympic Gold 2010 2SS RS Aqua Blue 68 Z/28 Lemans Blue C7 Corvette 68 SS Lemans Blue |
The Following User Says Thank You to luv2sixty9 For This Useful Post: | ||
Incase you dont need the whole kit you can purchase individually.
Here are some of the different headmarkings for hood hinge to hood. Anchor over T Anchor under T Anchor -centered- RBW. these are excellent restored original pieces. 45 per set of 4 shipped to the lower 48 if paid with PayPal friends and family |
