Old 04-24-2019, 09:46 PM
Enoch Enoch is offline
68 and 69 Camaro/Firebird rear axle rubber snubbers. These are the two snubbers that mount to the bracket that bolt on the frame rail to stop the axle from bottoming out. Excellent original pieces. If you notice the original part number scratched out from the factory new one's put in and the mold marks on the side of the one and on the face of the other. Extremely nice pieces as pliable as the day they were made. SOLD $100. SOLD
Old 04-25-2019, 12:46 AM
Very nice 9 C AC Delco 515 voltage regulator. Forgot I even had this went out in the shed and saw it sitting in a bag. Took the cap off 20 years ago to paint it. $80 + 10 to ship to the lower 48
Old 04-25-2019, 05:06 PM
J56 JL8 original single crimp front rubber brake lines. Had these for over 20 years. SOLD $200 SOLD
Old 04-25-2019, 05:59 PM
Camaro Chevelle Nova Impala 12 bolt rear end cover excellent condition. Was repainted over 20 some years ago and has a couple of chips and Nick's in the paint from sitting around. Just needs to be re sprayed real quick. Was an absolutely perfect pit free piece to start with. SOLD $80 + $20 to ship to the lower 48. SOLD
Old 04-25-2019, 06:02 PM
Cowl induction flapper door frame. Original , this was removed from a pace car 25 years ago. Very nice original piece can still see the marks from the Star washer mounting bolts. $40 + 12 to ship.
Old 04-26-2019, 06:24 PM
67 - 69 Camaro rear spoiler mounting hardware. I have one set that has the four nuts with the large washet and Anchor stamping on the underside and the four nuts with the small washers and -s s- stamperd ot the top flat of the hex. $80 ppff ***********SOLD**********
Second set is for four original acorn nuts (2 are nice and 2 have pitting). Some cars ised these on the rear studs in place of the small washer nuts. $50 ppff ************SOLD ************
Old 04-26-2019, 06:28 PM
67 369 Camaro front spoiler mounting hardware. Restored excellent condition. The four small cad bolts have anchor head marking while the four larger bolts with flat tips have E in a circle for their head marking and the four long bolts with a pointed tip have an E for their head marking. Extremely nice condition. $80. ***************SOLD***************
Old 04-26-2019, 08:07 PM
68 69 Camaro rear axle snubber to frame rail bracket mounting bolts set. Excellent original restored pieces. Both small and large washer bolts have E head marking. $60. Two sets available.
Old 04-26-2019, 10:12 PM
63 through 65 and 66 through 72 left hand alternator mounting bolts small block. Excellent restored condition. Included in the set is a long CP lower pivot bolt a short RBW mounting bracket to exhaust manifold bolt and an original WB head marking top adjusting bolt with star washer and thick flat washer. $50. Two sets available. Excellent restored pieces. (X)
Old 04-26-2019, 10:31 PM
67 through 68 Z28 and l79 curved neck thermostat housing mounting bolts. Two sets - excellent original restored pieces. First set long bolt has CP head marking short bolt is NAT. Second set has the (**SOLD SBC (SOLD**) for the long bolt and M for the short bolt. $40 a set. (X)
