1984 pro street monte carlo ss "the full monte"
*Posting ad for a friend---ALL information listed below was written and prepared by the owner, given to me and is posted as such.
The engine is a 502 GM crate motor, with aluminum heads. Disassembled and blue printed, heads are ported and polished, Stealth intake manifold port matched to heads and it's fully polished. 850 Holley double pumper w/chrome bowls and attachments. Hand made air intake fully chromed takes air from cowl induction. Under hood is polished aluminum and stainless steel and plenty of chrome as well! A Nascar-type aluminum radiator cools the engine and also comes with twin Nascar electric fans. Engine has power steering and functional air conditioning and is all new! The engine's been dyno'd at just under 600HP on pump gas and have dyno sheet to verify as well. Easy start up and easy run and maintenance. Engine bay is almost flawless with countless hours of custom work that make it a multiple show winner!!! The transmission is an ATI 350 Turbo built to handle 750HP and has full manual reverse valve body. A 3000 stall converter, gear vendors under/overdrive on transmission...six speeds when you want them or three speeds w/overdrive. Custom made shifter handle on a Hurst shifter--has two buttons, one for overdrive and one for line locks (or may be used for NOS). Engine has studded block--it will take it, but it is not needed. The rear is a Currie 9inch Ford with 4.11 gears. Has a three link suspension. Rear 15x14 Warrior wheels w/Mickey Thompson 33x19.5x15 tires. Fronts are 15x7 Warrior wheels w/215/70/15 tires. 12inch disc brakes front and rear w/emergency brake operative---it goes fast and stops fast! The rear seat has been fitted back into car around tubs. It also has functional power windows and lots of new glass. Full function Dakota digital dash and looks great! Removable anti-theft steering wheel and battery cut-off w/removable key in trunk. Pictures cannot do this car justice. This car has way too much to list! It looks great, rides great and is a rocket ship when called upon! You won't be dissapointed! *ASKING $40K OBO...No expense spared and no corners cut--*Serious buyers are welcome to view and inspect the car. Please feel free to call the number listed below to ask ANY questions. Located at Academy Automotive Center in the heart of Northeast Philadelphia. Thank you. Academy Automotive Center 9410 Clark Street Phila., Pa. 19115 Phone: (215)464-2440 Ask for Slim (Joe Ulanowski)
I currently own a 1969 Camaro SS350. Although the original drivetrain is long gone, this 4/speed car has a March '69 HC coded block with #041 heads. The transmission is an M20 Muncie #660 case and the rearend is a BS coded 12 bolt posi. Built in Van Nuys. |
