Old 01-28-2020, 08:59 PM
Default Race Brake
I am thinking about trying to make this. It is not that complicated, The brake arm seem to be the biggest item, I think I will use a hurst shifter handle. Has any out there tried this before?
Attachments - The Supercar Registry Sanders drag brake.jpg Sanders drag brake 2.jpg IMG_3588.JPG IMG_3587.JPG
Old 01-28-2020, 11:27 PM
wheelhop wheelhop is offline
Maybe a company who makes hand controls for handicapped drivers could make if for you.
I'm somewhat handicapped myself when it comes to drag racing !
Old 01-29-2020, 12:01 AM
Spooky's Avatar
Spooky Spooky is online now
I drove a buddy's 4th gen Z with hand controls. Its a little different setup than that. It has both the throttle and brake functions on the same stick. He is in a wheel chair and he got that car in the 11's!
I like the idea of making one using a Hurst shifter. It would freak a lot of people out at a show!
69 Camaro RS/SS X22 4speed NOM but working on something special
69 Camaro x11 355 crossram m22 12 bolt 3.73's
Old 01-29-2020, 12:02 AM
John Brown's Avatar
John Brown John Brown is online now
Frank Sanders 63 Z-11 had the only mechanical one I ever heard of, but it went sideways. Dick Brannan had one off a Studebaker, but never saw a picture of it so don't know if it was mechanical or electric. Stude used both kinds.
John Brown
Old 01-29-2020, 02:41 AM
ZAPPER68 ZAPPER68 is offline
I made one a few years ago for my '55 Chev Gasser using a combination of old shifter parts and some good old ingenuity. The trickiest part was getting the angle correct between the handle and the rod/sleeve attached to the brake pedal.
Once I had that worked out the brake worked perfectly... I live in British Columbia, where using the brake at an uphill/downhill traffic light came in handy. The curved Hurst shifter handle (installed vertically & backwards) in conjunction with the shape of the dash was a perfect fit.
I used adjustable shifter rods at each end of the fulcrum which enabled 'fine tuning' of the rod/sleeve. A light spring is required to ensure the handle is kept in the 'ready' position. :-)
The Following User Says Thank You to ZAPPER68 For This Useful Post:
Xplantdad (01-30-2020)
Old 01-29-2020, 04:14 PM
Keith Seymore's Avatar
What's the process for launching a car with this device? Or does it just help to get staged properly? How does it help take the slack out of the driveline?
Does it toggle overcenter, and hold the brake? Or does the driver hold the lever to apply the brake?
The reason I ask: in my stick shift car, once the car is "staged" the foot brake is no longer needed. The car sort of settles into the slicks (wrinklewalls) and does not move.
Set the launch rpm, sidestep the clutch when you see the last yellow, and away you go!
K
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph best
markinnaples (01-29-2020)
Old 01-29-2020, 04:15 PM
I'm not sure an "increase in ET" is much of a selling point...
'63 Grand Prix
Old 01-30-2020, 12:48 PM
Thumbs up
K
I believe race brakes were used before line locks came on the scene. As mentioned in my case, with a 4 speed the brake is particularly useful at traffic lights where I live in the mountains...it works exceptionally well and I used it all the time.
I never used the brake at the track because I had a line lock for that exercise. However, without a line lock it would be useful to 'take out the slack' easily by clutch/race brake coordination...thereby possibly preventing a hard launch (& broken parts) clutch cars are notorious for. As we all know, sidestepping the clutch is brutal on the drivetrain which is something we're all guilty of at one time or another :-)
When properly adjusted it will not overcenter and you must hold the lever (in my case the old Hurst shifter handle) to apply the brake. Easy peasy... Over centering will definately be an issue, especially in traffic for the folks lined up behind you with the traffic lights on green and your brakes are jammed. Not a good situation!
Without exception, whenever I was at a car event people always asked me 'what the heck does that lever up by the dash do'? Once they understood the mechanics of the device they thought it was pretty cool and asked where I got it from. With a couple of modifications, I made mine using the same picture as a guide in your initial post.
Old 01-30-2020, 03:21 PM
Thank you for the additional detail -
K
'63 Grand Prix
Old 01-30-2020, 05:12 PM
earntaz earntaz is offline
K
I don't know if this is relevant -- but if you're drag racing in a class where "no electronics" are allowed (such as a line loc) this device may be of an advantage. TAZ
