Old 08-13-2020, 03:55 PM
wthirty1 wthirty1 is offline
Default Door Panel Water Shield Black Tape
Trying to decide on the correct black tape used to hold the paper splash / dust shields over the door. It's a 2.5" black tape...I'm leaning towards Gaffer Tape. It's water proof which makes sense. Curious what others have used on their restorations. Thanks!
1970 Cutlass S W-31 - platinum, blue stripes, blue buckets, M14 3-spd
1970 Cutlass Supreme Y74 Pace Car #79
1970 Rallye 350 - automatic, original paint survivor
Attachments - The Supercar Registry tn_IMG_7717.JPG tn_IMG_7711.JPG tn_IMG_7677.JPG tn_IMG_7673.JPG
Old 08-13-2020, 10:24 PM
Remmag Remmag is offline
Try 3m caulking strips
Old 08-13-2020, 10:50 PM
rlw68's Avatar
rlw68 rlw68 is offline
I recall Steve Shauger mentioning the 3M cloth friction tape is close to the one used on assembly lines.
Rob
Old 08-14-2020, 10:14 PM
I thought they used black caulk strips for the paper splash also. That's what my cars had.
Old 08-14-2020, 10:31 PM
SS427's Avatar
SS427 SS427 is offline
Though I normally find the black tape at the top of the paper, it was on the bottom on our Yenko. The tape was a wide black masking type tape which I replicated. There was also the black strip caulk as well. This is pretty indicative of what I find on every car I tear down.
Rick Nelson
The Following 2 Users Say Thank You to SS427 For This Useful Post:
Woj (08-15-2020), ZLP955 (08-15-2020)
Old 08-15-2020, 07:34 AM
mssl72's Avatar
mssl72 mssl72 is offline
Well, I had replied before and realized you said it was waterproof. I've seen black paper tape most of the time. It seems like they used black chalk and tape to help hold it in place. The black tape I've used before for, for things like light bleed from a gauge package is an "artist" tape. It's used a lot on stages and displays. There's a sorta semi flat and a flat black. The brand I've used before is made by Shurtape. Shurtape has a website. There's a staging place near me in Burbank that sells it. I haven't seen it in 2.5", but they have a 2".
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
Old 08-15-2020, 10:36 AM
JKZ27 JKZ27 is offline
Possibly similar to the black tape used on the Camaro subframe mounting holes?
Discussed at CRG
http://www.camaros.org/forum/index.php?topic=17154.0
Old 08-15-2020, 11:33 AM
R68GTO R68GTO is offline
Good point. It would make sense that they would use the same water-proof tape throughout even though it would be applied much later in the process. I'm going to go measure my original water shield tape to check the width. That CRG thread has a bunch of "guessing", including me on what the floor pan tape with was.
