64 Ford Galaxie 427
I came across the remains of a 1964 red/red Galaxie today. It was a manual trans. The door tag and vin are still there. The door tag says rear end code 4 trans 1. The junyard wrote in yellow marker 427 4x2 on the hood. Motor and trans are gone. Is there a way to find out if this was a factory 427 car? Does it have any value as a rusty incomplete car? Earl
Re: 64 Ford Galaxie 427
R code in the vin ?
I will have to go back and check out the vin. Did not write it down. Just looked at the door tag. Earl
Can you take some digital pictures of it & show them here?
I will take some digital pictures. Should have them up early next week. Thanks Earl
It should have an "R" in the door jamb tag and also on the firewall passenger side will have a stamped tag that is part of the firewall. "Q' is a 427 410 HP single 4 barrell...BKH
its up top of th efirewall and can be seen with the hood open from the top.. Look for thr R or Q (single 4 barrel carb)
[ QUOTE ] It should have an "R" in the door jamb tag and also on the firewall passenger side will have a stamped tag that is part of the firewall. "Q' is a 427 410 HP single 4 barrell...BKH [/ QUOTE ]
Frank Szymkowski 1971 Torino 351c 4v GT convertible. White/white with black,4 speed, shaker, am/fm, ps/pdb, buckets/console, ac, flip headlights 1969 GTO Judge Warwick blue/blue, RAIII, 4 speed, tach/gauges, safe t track, flip headlights, 3.55's, ps and radio. |
The tag is still on the firewall. Tag is in the door as well. I do not think it has a R. Looked for that. It may have a Q. Will get back for a look early next week. With the digital camera. Earl
False alarm. No R or Q code. Some one got a good laugh with the 427 hood writing. Earl
At least you were smart enough to follow up and investigate. I have learned the hard way, follow up on every lead when possible no matter how far fetched.
Rick
Rick Nelson Musclecar Restoration and Design, Inc www.musclecarrestorationanddesign.com https://www.youtube.com/watch?v=62r-6vgk2_8 specializing in (only real) LS6 Chevelle restorations |
