Old 01-03-2020, 12:52 AM
Yes...
You guys are both correct. I'll continue cleaning it up, will seal the inside and hang it back in the car without trying to remove the dent. Thanks for the lil' nudge as you guys are spot on, and that helps keep me on point. Thank you for chiming in.
mockingbird812 (01-03-2020), olredalert (01-03-2020)
  #212
Old 01-03-2020, 09:13 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Agree with all, leave the dent, put it back in place. Nice work Graeme
I ain't nobody, dork.
The Following User Says Thank You to Tracker1 For This Useful Post:
NorCam (01-03-2020)
  #213
Old 01-04-2020, 02:47 PM
Sorry, I can't help myself, but I wouldn't change it to power steering either. If you aren't going to change things, then don't change things.
NorCam (01-04-2020)
  #214
Old 01-04-2020, 04:00 PM
GrumpyJeff's Avatar
GrumpyJeff GrumpyJeff is offline
Any decent PDR guy could get that dent out in 5 minutes !
The Following 2 Users Say Thank You to GrumpyJeff For This Useful Post:
DW31S (01-12-2020), NorCam (01-04-2020)
  #215
Old 01-04-2020, 06:20 PM
Yup...got that Freddie. And just to clarify, I am adding it.
big gear head (01-04-2020)
  #216
Old 01-04-2020, 08:12 PM
Zedder's Avatar
Zedder Zedder is offline
It’s interesting to see the various perspectives on what to do with a particular car. I love this car for what it is...a super clean 69 Z in cool colors. Would I like it less with a new gas tank? Absolutely not. To me, once a car is repainted, little changes to improve the car doesn’t bother me in the least. The dented tank would bug me and I would wonder if it might be weakened in some way from the dent. That would make me change it and save it for the next owner if they wanted to put it back in.
I also am wary of keeping original parts that might fail and cause damage if I was going to drive the car. The example that I keep remembering was in 1997 at the NCRS regional at Bowling Green. I was learning how to judge in the C3 Bow Tie class and a guy had a 74 vert with sub 2,500 miles and original tires. He didn’t bring another set for his PV test and decided to do it with his original Tires. As luck would have it, he blew a rear tire during the test and busted his left rear quarter panel! He nearly cried...
Mark
1996 Carrera & 1993 Fat Boy
The Following 2 Users Say Thank You to Zedder For This Useful Post:
KLars1 (01-04-2020), NorCam (01-04-2020)
  #217
Old 01-06-2020, 11:39 PM
Pulled the engine and trans out today to further access to cleaning and detailing. Things are progressing along but not at breakneck speed. Having fun though, I am. Once the engine was out. I was able to get a clear shot of the casting date on the back of the block. Adding that picture here for reference purposes. It closely matches the front stamp which I had not posted earlier. Block was cast 8 days earlier than it was stamped on the front pad for the build date.
Old 01-06-2020, 11:49 PM
With the hood off and the engine out, I got into the engine bay to get a better look at things. I also took some better pictures of the stamps and the firewall piercings for the speedo cable and cowl hood wiring. Even found this CF marking on the speedo cable.
R68GTO (01-06-2020), ZLP955 (01-07-2020)
  #219
Old 01-07-2020, 12:45 AM
At the same time, I also snapped a couple of pictures of the 309 D3 master cylinder and the 9204 brake booster. The brake booster is dated 268 while the US stamped 309 master cylinder looks to be dated 174. It was really hard to see these numbers until I rubbed a little paint off where the date was cast. Pretty sure it says 174. Going to remove the hard lines now and continue cleaning them up to remove any black paint.
Old 01-07-2020, 01:25 AM
Transmission is now on the bench. Checked out the original 660 case which is mint with no damage ever to the front mounting ears, and no evidence of ever being abused. Of course, it has the 584 tail housing and 648 side cover, but what is awesome is that all factory hardware with correct head markings are still intact. Even has the original front bearing retainer locks, factory tag on the cover, and looks like the shifter mount has never been off. Going to continue cleaning the floors in the tunnel before this goes back in.
