Old 02-24-2019, 09:09 AM
Martin Martin is offline
Default Tribute '69 Camaro said to be 'best in the world'
For sale at a dealer in the UK (I have no connection)
I ask for your critique, so I can learn more
It might already be known to you guys, show winner, magazine car, celebrity owner who surely could have afforded a real one.
Thanks
Lots more photos on the website
https://www.woldsideclassics.co.uk/c...-louth-6378594
Heater delete?
Power steering delete?
No dash clock?
Floor pans underneath color ?
425 hp decal missing off aircleaner ?
Alternator pulley & bracket colors/finishes?
Inner fender paint too shiny?
Brake pedal missing the disc brake emblem?
The Following User Says Thank You to Martin For This Useful Post:
68Tiger (02-24-2019)
Old 02-24-2019, 11:51 AM
m22mike's Avatar
m22mike m22mike is offline
Nice cowi trim tag...
Old 02-24-2019, 12:01 PM
68Tiger 68Tiger is offline
Wow, very nice COPO Camaro tribute. Interested to hear and learn what the experts have to say as well.
1969 Camaro RS
Old 02-24-2019, 12:41 PM
bbbentley's Avatar
I’m not going to pour over the photos, ‘cause I could rip it a new one. Just casually glancing - window crank knob color, vertical stainless in tail light lenses, engine temp sensor and wire, battery ground location, never had a heater delete off the assembly line. No such thing as P.S. delete, door striker screws not painted, lower alternator bracket incorrect, upper control arm brushing washer color wrong, S.Plug heat shields wrong, proportion valve bracket of master cylinder should not be plated. H2O bypass hose clamps wrong, shifter arms and clevises wrong, driveshaft stripe at wrong end, bunch of B.S. “resoration graffiti”, leaf spring technically wrong, gas tank straps wrong color.... I’m tired , let someone else take over.
FULL OWNER HISTORY
The Following 4 Users Say Thank You to bbbentley For This Useful Post:
68Tiger (02-28-2019), m22mike (02-24-2019), Martin (02-24-2019), X66 714 (02-24-2019)
Old 02-24-2019, 12:50 PM
Should the rear end be a BE instead of BV, or am I seeing something wrong?
Old 02-24-2019, 02:26 PM
X66 714's Avatar
X66 714 X66 714 is offline
Over detailed underside. No undercoating in wheel housings, tail pipes too low, stance seem too high, trim tag should have paint on it. Looks like it's been off the car. Hood latch should be Phosphate. Has a chrome shift ball. GM sticker in door. Bolts that hold the rear license frame are wrong. Now I'm tired Bentley....Next...Joe
The Following 2 Users Say Thank You to X66 714 For This Useful Post:
68Tiger (02-28-2019), Martin (02-24-2019)
Old 02-24-2019, 03:38 PM
William William is offline
Saw it at SC Indy 2002. Did not have the LH tailpipe adapter; repro tag. Many resto errors.
124379N651505
The Following 2 Users Say Thank You to William For This Useful Post:
