Old 11-09-2013, 05:14 AM
ds1 ds1 is offline
Default 427 aluminum block
I purchased this tonight having known about it for a few years. Who in the PA, MD area is good at repairing aluminum? It has led a hard life. But after seeing the casting date I bought it. How many were made? The block was decked so no numbers are on the front deck. Interested to hear what you folks know about these. You can see where someone ground the Winters foundry mark off.
1967 Camaro conv (first car)
1969 Camaro street car
1967 Super Stock SS/JA Joe Scott car
Old 11-09-2013, 04:17 PM
69VN's Avatar
69VN 69VN is offline
Default Re: 427 aluminum block
Jerry MacNeish's Camaro High Performance, Inc. does such repairs. The website is www.z28camaro.com
Good luck,
SAL
I currently own a 1969 Camaro SS350. Although the original drivetrain is long gone, this 4/speed car has a March '69 HC coded block with #041 heads. The transmission is an M20 Muncie #660 case and the rearend is a BS coded 12 bolt posi. Built in Van Nuys.
Old 11-09-2013, 10:53 PM
DW31S's Avatar
DW31S DW31S is offline
MacNeish does have a shop that can handle aluminum repairs. I took a Muncie case there for repairs and the work was perfect---not cheap, but perfect.
Old 11-09-2013, 11:24 PM
69SSZL1's Avatar
69SSZL1 69SSZL1 is offline
Theres even people that can put the winters back on
1968 Z/28 34,000 mile, born with engine and trans, Shipper, California car, Fathom Blue, deluxe interior, M21, 3.55 Posi
1962 Oldsmobile Jetfire, Factory all Aluminum V8 Turbocharged and Methanol Injected TURBO ROCKET engine, 4 speed Hydramatic, 4 link rear suspension, 3.36 Anti-Spin differential, California car, PS, PB, PW, AC, Jetfire 2 option package.
Old 11-10-2013, 01:11 AM
ds1 ds1 is offline
I know he has good work done. I am trying to find out who does it for him. I am in the middle of PA where circle track racing is king. This engine out of a sprint car and they have a stroker crank that was in it. They thought it was 513 inch.
Old 11-10-2013, 10:41 PM
Fast67VelleN2O's Avatar
I have a ZL1 block dated 5-7-69 so they were pretty close!
Day 2 is Life.
Old 11-10-2013, 11:55 PM
ds1 ds1 is offline
I have seen dates 5 14 69 and 5 28 69. I am trying to find when the blocks were cast, what dates. I was trying to find out how many were made. The numbers I found were between 300 to 500, but many were junked in machining. I read about the blocks being numbered on the rear and the main caps being numbered also. I got the matching number main caps with the block. I looked into buying this block after reading about the ZL1 cars, knowing that the low production of the blocks and costly price kept people from throwing them out after they were broke. As I said earlier it came out of a sprint car. When I asked about the broken pieces I was told they would be outside turn 2 at Port Royal Speedway. They last ran it about 1992 and it sat under the work bench. I saw it 6 years ago when I bought a set of factory heads from them. I figured it was beyond repair. I guess I am going to find out.
Old 11-17-2013, 03:20 PM
ds1 ds1 is offline
Found out 10 ZL1 cars were sold here in PA and 2 were from Sutliff Chevrolet in Harrisburg which is closest to me. My block could be an over the counter from Sutliff, but was decked so the numbers are gone. The stolen car from Bethleham is close also. York is 2 hours away, Ammon R Smith. Trying to figure out if it is a production car block or not.
Old 11-17-2013, 04:07 PM
William William is offline
With a casting date of 5 15 69 there is virtually no chance it was an original engine in one of the 69 production ZL1 Camaros. By that date 67 had been delivered. The last two were final assembled on or about June 3, 1969.
Unlike production cast iron engines commonly built within a week of their casting date, the span between casting date and pad assembly date for production ZL1 engines was considerably longer.
It is possible it was built as a service engine assembly as several have been located. Production engine codes were ME, MG, ML, MM.
Old 11-17-2013, 04:30 PM
Did you look by the oil filter for a vi stamp ?
