Old 09-27-2015, 11:34 PM
1968 nova ss 1968 nova ss is offline
Default Gray phosplate coating
Wondering who you guys recommend for gray phosphate coating for hood hinges and latches for my other 68 nova ss....lookin for shop that does a good job with reasonable turn around time.. thanks in advance,Chris Teed
Old 09-28-2015, 12:49 AM
x77-69z28's Avatar
Default Re: Gray phosplate coating
www.z28camaro.com
Old 09-28-2015, 01:12 AM
If you can get the parts media blasted locally you can do it yourself very easily and cheap.
http://www.palmettoenterprises.net/P...-Welcome-.html
Old 09-28-2015, 01:15 AM
It does create a bit of an odor, but you can obtain great results doing it outside on a grill. Learned that tip from Charlie.
Old 09-28-2015, 12:27 PM
earntaz earntaz is offline
How durable is this coating -- like factory? Thanks
Old 09-28-2015, 12:33 PM
I can't tell any difference. Get something like a stainless salad bowl etc from Walmart that is big enough to hold the parts you want coated, put some solution and water in it on a outdoor bar-b-q and get it hot. Put the parts in and make nut and bolt soup. Have some tongs or a ladle for lifting the parts out to check on the color. When the parts are dark enough for your liking take them out, rinse and then coat with something like WD40.
Old 09-28-2015, 12:49 PM
m22mike's Avatar
m22mike m22mike is offline
There are many good links on the interweb and Youtube that deal with phosphate coating. I just use Prep and Etch from the box store, about 15 bux a gallon. Oven proof glass ware works good for small stuff.
Here is one
Home brew phosphate
Mike
Old 09-28-2015, 01:01 PM
protree68 protree68 is offline
I believe it's called Burbank plating in Burbank California they have a 24 by turn around service and its cheap
69RS Z/28 first cowl hood car built 12C
69RS Z/28 X33 RED/RED
69RS Z/28 VE3 -- STRIPE DELETE OIRG PAINT
69 L78 X22 convert survivor VE3 ,POP
70 HEMI CUDA ORIG PAINT 19K MILES
70 LS6 M22 4.10 4k Miles Black time capsule
Bill Hunter Yenko
Old 09-28-2015, 01:02 PM
cook_dw's Avatar
cook_dw cook_dw is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: m22mike</div><div class="ubbcode-body">There are many good links on the interweb and Youtube that deal with phosphate coating. I just use Prep and Etch from the box store, about 15 bux a gallon. Oven proof glass ware works good for small stuff.
Here is one
Home brew phosphate
Mike </div></div>
This is the method I am using. I use a hot plate for bolts and small brackets.
Old 09-28-2015, 01:59 PM
m22mike's Avatar
And a word of caution with the hot plate, do not get it to hot, makes a foamy mess.. [img]<<GRAEMLIN_URL>>/shocked.gif[/img]
