Old 03-17-2016, 12:39 AM
lbnaz lbnaz is offline
Yenko Premier Member
Default NOS GM Camshafts with rust on Journal Surface
Has anyone used a GM camshaft that has what I would consider minor rust on the bearing journal area. Its not crusted by any means just like it was stuck in the tube in various spots. I haven't tried to clean it yet and wondering what would be the best process to do. Its a GM nos BBC 180 camshaft will be putting it into a L88 motor for a little more bump. Thanks, Larry
Old 03-17-2016, 01:35 AM
Stefano Stefano is offline
Default Re: NOS GM Camshafts with rust on Journal Surface
Submerg it into some evap-O-rust. That should clean it up.
Old 03-17-2016, 08:48 AM
ds1 ds1 is offline
You can buff it with crocus cloth
1967 Camaro conv (first car)
1969 Camaro street car
1967 Super Stock SS/JA Joe Scott car
Old 03-17-2016, 07:13 PM
njsteve njsteve is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Stefano</div><div class="ubbcode-body">Submerg it into some evap-O-rust. That should clean it up. </div></div>
It worked wonders on my rusted 455 crankshaft.
Old 03-19-2016, 01:13 AM
Hello, thanks for the evap-o-rust idea I tried it and here are the results. Soaked for 12 hours each side. Anyone see any reason why this cam could not be installed. Before and after photos. Larry
Old 03-19-2016, 01:53 AM
scuncio scuncio is online now
I would still hit it with some crocus cloth, but I wouldn't be afraid to run it....
Old 03-19-2016, 03:05 AM
X2 Use it!
Bill
Old 03-19-2016, 05:56 AM
Go with it!
Jason
Old 03-19-2016, 03:00 PM
resto4u resto4u is offline
you could wet sand it with 1500 up to 3000 to finish. And you could use oil or WD-40 instead of water. That cam should be fine, just make sure it is polished.
67 Z28, 67 RS/SS 396 Canadian, 73 Camaro Z28/LT Carolina Blue
Old 03-19-2016, 04:23 PM
Paul_S Paul_S is offline
Yeah, definitely wet sand with WD-40 or similar light oil. Clean up, buff with crocus cloth and clean again. Need the surface polished. Random small spots/micro-pits are ok. I'd be worried about if full width of journal surface is scarred with pits you could feel with your nail. Hard to tell in the pics.
Paul
'64 Nova (400 Series) 2-dr Sedan, 4-spd
Zweigle's -Best "Hots" in the Universe
